I'm like a little kid at christmas, can't wait :thumbsup:
I am going to the following places:
Top Secret
Nismo
Crystal
UP Garage - Might they have R34 GTR Wheels?
Superautobachs
What else is around the Tokyo area that I should be visiting?
Also is there any way of finding some kind of drifting event or cruise or meeting on during next week some where around the Tokyo or the surrounding areas? I've heard of Daikoku, whats the nearest underground station, taxi from there I guess, will it be on Friday 18th, if not is there anything else on?
Cheers
P.S Any tips and tricks of travel from the residents?
Oh also looking for breakers yards for some R34 GTR Wheels...
https://www.sau.com.au/forums/topic/64328-going-to-japan-on-sunday/
Have you got your Jap rail pass yet? If not I suggest you get one they are a bargain!! Ride the shinkansen (bullet train) to somewhere at 280kmh in complete silence it is surreal. As for wheels any big foot store or similar will have sets of R34 GTR wheels to choose from at ridiculous prices. If you are in Tokyo, Saitama is probably the best place to go to get them, about 1/2 hour train from downtown Tokyo
I was there last Feb and went to a Big foot ( sells new and used wheels and tyres) in Saitama and they had at least six sets of genuine R34 GTR wheels and tyres for around 80,000 yen/$1000 oz which would be maybe 450 quid? Don't know about the rental the trains are that great I don't know why you would bother especially if you are not with someone who can navigate while you drive. Have you got a rail pass? If not you will need to get one BEFORE you arrive in Japan, they are not available in Japan. Also to be eligible you need to make sure that the immigration bod stamps on your passport that you are on holiday otherwise they won't honour the pass. A weeks unlimited travel around Japan I think from memory was 35,000 yen which is dirt cheap. you can't ride the Nozomi which is the fastest but hey the other ones (can't remember what they are called ) still haul arse!!
Ok, thanks, I meant original R34 GTR Wheels though, is there a breakers or something like that?
How much is a rental?
Cheers
When i was in Osaka last Nov -December , i rented a Mazda demio ( Mazda 2 in Aus) for 4000 jpy per day from Mazda ( unlimited k's ) but paking at the hotel cost me 2000 jpy per day and tolls are very high as well . In 3 weeks i covered 3000 km and i paid about 30,000 jpy in tolls .
I found r34 gtr rims in up garage , most were around 100-150,000 jpy with tyres .
also found a set in blackchrome with brand new tyres , the price tag 300,000 .
You need to buy one from a travel agent (at least that is how it works in Oz) and have it on you when you arrive in Japan. I think it is because it is so cheap. The shinkansen is fantastic but quite expensive, especially if you want to travel a bit. Tokyo to Nagano return was I think about 18000 yen and it is about an hour and a half trip. Anyway ask a travel agent and they will be able to steer you in the right direction. It covers you for subway, shinkansen and ferries anywhere in Japan so it is a great deal! www.japanrail.com/ will answer all your questions I think.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
