  • Replies 630
" ACT Policing continued its high-priority patrols for street racers on Friday night, dispersing a large group of drivers gathered in Hume.
Frequent checks were made on the Federal Highway and around the streets of Braddon and Mitchell, other well-known hotspots for hoon behaviour.
Traffic Operations manager Sergeant Jeff Knight said police were acting on information received on Thursday, which warned of possible street racing on the Federal Highway, between the roundabout at the top of Antill Street, Watson, and Eagle Hawk.
Along with marked and unmarked cars, Operation Halite detectives were patrolling these areas gathering intelligence, including video surveillance.
No-one was booked for street racing offences on Friday night or yesterday morning, an ACT Policing spokesman said. However, the lack of cooperation from certain people in Hume at about 10.30pm, when asked to move on, almost saw the defect team called out.
Sergeant Knight said burnouts and street racing went hand in hand, but the former was a bigger problem in Canberra. "I'm putting together a strategy at the moment, which will include a lot of things including technology, and we're really going to hit 'em hard."
Part of that strategy involved 19 of his traffic squad members, who were each assigned a sector of Canberra that they must take ownership of, and patrol at least once a shift.
There would be covert surveillance and a dedicated team to concentrate on burnouts, while he also called on residents to phone through information about offenders, such as vehicle registration details.
Police have powers to seize a vehicle involved in burnouts or street racing for up to three months for a first offence, while a repeat offender could forfeit his or her car altogether."
Interesting...
Thanks for the heads up.
Let's just hope they don't go crazy with Operation Halite and nip every little gathering that happens on a Friday night simply because a group of nice cars meets up.
and on what grounds can they have to ask you to move on?
if we were a group of 50 yr old, austin martin, enthusiasts, quietly chatting about our cars, would they tell us to leave? i dont think so.
im pretty happy to do what im told when it comes to police, but its one thing i wont put up with and if push comes to shove i'll be refusing and telling them where they can go.
so yes, i will be ruining it for everybody!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
