Hey
JUst wondering how difficlult is it to find parts for a Toyota Sprinter throughout the south east queensland area as i am looking to buy one but am worried about drift damage and body parts if you know what I mean. So was just wondering if anybody has knowledge of any places/wreckers etc can supply body panels/dorrs etc and is it costly?
https://www.sau.com.au/forums/topic/64394-hachi-roku-parts/
Parts are pretty hard to find for Sprinters - and the most wanted items such as LSD's are expensive - roughly $1100 for a second hand one. From what I've seen, these have some inherant rust problems in the rear quarters around the windows and in the boot.
https://www.sau.com.au/forums/topic/64394-hachi-roku-parts/#findComment-1206811
there's a company in shepparton VIC that's pretty good for sprinter parts.
what are you after anyways... I'm selling a few things I stripped off my sprinter track car soon (mostly useless stuff though like aircon n stuff) keeping all the doors panels though :P I do have Trueno flip up headlights as I decided against a Trueno conversion... N2 Levins look much tougher :D
https://www.sau.com.au/forums/topic/64394-hachi-roku-parts/#findComment-1207146
yeh Azzurra i am interested got ne links or any info about the srpinter? DAMN!!! $1100 for a 2nd hand diff!!!!!!!!!!!!!! flip up lights are awesome yeh ur right much tougher look. But yeh I am just a little worried about the rarity of the parts for it as it will be serving a purpouse.
https://www.sau.com.au/forums/topic/64394-hachi-roku-parts/#findComment-1207617
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
