Ok... u got it with jap instructions hey...
Go to channel 1.
Set it to manual...
Set the boost to 43
set the gain to 10
this setting should be round 10psi
play with the boost number higher/lower to get the desired goal...
Do not use auto, this setting takes to long to learn. Use manual and spiking is not an issue and it will hold all the way to red line.....
Do not play with the gain setting. Leave it on 10. Otherwise you will run the risk of boost coming on too hard and you may bog a ring....
External wastegates require a gain setting of around 40....
Stock wastegates 5-15.... i found 10 to be a good setting...
