Nissan Skyline R33 GTST Type M, 95 model. 5 speed manual, Black in colour. Have spent thousands in looks and performance on the car. No expense spared!
EXTERIOR
- sprayed and detailed brake calipers
- 400r front bar with clear indicators
- GTR grille
- R34 GTT rims
- carbon fibre bonnet with pins, still have standard bonnet also
- halogen bulbs for headlights
- clear side indicators
- lowered
INTERIOR
- R33 GTR seats and door trim
- Apexi RSM and stand
- Apexi EL boost gauge
- Blitz SBC electronic boost controller
- EL dials (2 colours blue and green)
- HKS type 1 turbo timer
- Nismo gear knob
- pioneer MP3 head unit
- hertz rear speakers
- pioneer front splits
ENGINE/PERFORMANCE
- Full engine rebuild at 94,000 kms. Now at 135,000
- HKS GT-RS turbo kit (400ps rating) Fitted with speedflow braided lines and fittings
- Machined exhaust manifold
- Gaskets replaced turbo, manifold and plenum with genuine nissan items
- polished exhaust manifold heat shield
- Large Intercooler with chrome/alluminium piping
- oil cooler with braided speedflow fittings and braided lines, custom built into front bar
- custom alluminium cold air box
- K&N pod filter
- Apexi 555cc injectors
- Bosch 044 in boot fuel pump
- Sard fuel pressure regulator
- custom surge tank recieving fuel from standard fuel pump
- custom oil catch can with K&N filter/breather
- ALL THE ABOVE FITTED WITH SPEEDFLOW BRAIDED LINES AND FITTINGS!
- turbosmart BOV type 1
- Z32 afm with Tomei plug
- splitfire coil packs
- NGK spark plugs gapped to 0.8mm
- new brake pads
- new suspension bushes
- 3' exhaust from turbo
- new highflow cat (1000kms old)
- CES split dump pipe. HPC coated
- Serviced every 5000kms with motul 300V engine oil ($140 for 6 litres)
- Redline gearbox oil
- new oil filter
- new fuel filter
- Apexi power FC
- Short shifter kit
- New Unique Autosports 1400kg clamp load clutch (1000km old)
- lightweight flywheel 4.5kg
Car has an 'autowatch' alarm system top of the range. Windows go up with alarm, immobilisers, motion sensors etc... All engine work was done approx 1000kms ago where all gaskets have been changed, and performance parts have been installed. Car is run on low boost 0.6bar, can be changed via electronic boost controller up to 1.2bar. Quick street car, responsive and fun to drive. Looking offers around $30,000. Contact Boro on 0410580010 or PM me regarding this sale.
https://www.sau.com.au/forums/topic/64452-black-r33-gtst-sydney/
DUUUUDDDE, your selling, why???? Such a nice car... Guys, this is a genuine immaculate Skyline with very nice modifications.
Good luck with the sale
yeah cant afford to keep it, looking at starting up a business so the car has to go. as long as i have it i will keep spending cash on it. Will buy one later on down the track if things to as planed... Pic Below more upon request....
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
