g'day guys,
wanted to post to see if anybody has had experience, or knows anybody trustworthy who can truck a car down to canberra from coffs harbour?
also, how much does this usually cost? time?
i know andrew (V33) had some bad experience before, but that was just in the ACT.
any help would be greatly appreciated
andy
https://www.sau.com.au/forums/topic/64494-shipping-car-interstate/
You need to ring the transport companys, if they have a spare slot on one of the big car traliers they can do it cheap just fill the load. As my brother had his boat shipped down like that. Cost well you will have to ask them nicley
Talk to TNT, they do car couriering for the best price (I think it was TNT anyways...). The only downfall is they have a limited amount of "low clearance" trucks, so if the car is lowered you might have to wait a while for a truck to do a BNE -> SYD -> MEL route before it can pick your car up.
yeah my experience was with a tow company, who shall remain nameless
----------------------> QUIKEZE TOWTRUCKS ARE THE DEVIL<------------------------
and also with everlast aswell, but everlast didnt do to much damage, but Nik's pretty much right on the money, if the car is low let them know and ask them to make sure its looked after and you should be fine.
car from what i've heard from the owner and from the pictures i've seen, is very driveable and in excellent condition for its age. but i don't particularly want to drive it all the way from coffs just after buying.
the seller said he found some cheaper quotes on freighting. and that carways for $440 looks good.
just see what i can do with my current car, and if all goes well, will be having some fun by friday next week :(
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
