The base timing was adjusted too.
Made zero difference.
Cost me $600 to get nothing!!
So what was your base timing before and after? Did you alter the timing and fuel map (assuming you have a power FC or a S-afc in the case of fuel alterations only)
You can't expect nothing at all to happen as a result of a significant change in cam timing. Other things happen when cam timing is changed that make alterations to fuel and ignition necessary.
Did you try advanced and retarded settings?
I assume you still have the gear on mate?
Maybe we can get to the bottom of this :P
rev.
At the time, I had no means of adusting the fuel or anything.
It was put up on the dyno, power run done, old gear removed, new gear fitted, adjustments made to cam gear and base timing, and then spun up on the dyno again.
No difference. three of four adjustments made again, and still no difference.
See this thread for details.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=33462
The guy who fitted the gear now runs his own shop and actually tuned the PFC on my car recently. He remembers my car from the cam gear fitting and found it strange that the R34 showed no results.
I think some others have also tried this with the R34 and had similar results.
We think is has a lot to do with the constantly variable intake cam timing.
thats some good increases you got there benm from the exhuast gear and coil packs. Looks like these may be the next 2 mods i will have to do when the modding bug bites again as they seem very good value for money.
Jsut curious however, when sydney kid claims he has never seen any less than 15rwkw gain (which is very impressive considering the small cost) is that with any aftermarket management?
Let me just state before anyone runs out and buys one.
This is a fairly easy item to fit, but to set it up correctlly you need some help. Dont attempt to set this up on a trial and error basis or pistons will meet your valves.
I have found some info that says start at 4 deg's... Drive and watch knock sensor readings on PFC. Then adjust 1 deg at a time til you finally see the knck change then step it back 1 degree and tighten it down as hard as possible. Also mark with a pen so you can check for slipping at a simple glance.
Ill let you guys know the power gain. Im trying to get a dyno so we can run it in the morning then fit and run again. Give you guys an exact result and a simple guide on where to start. All info i have found said dont do it unless you can monitor knock sensors as this is your key indicator for limits.
Cheers Col
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
