Jeremy, what are you chasing exactly??
A normal attessa is more than capable of providing the driving ability /handling required.
As mentioned, a torque split controller will provide the adjustment required for the spirited driving phase when required.
As far as using a pro? I think it is only V Spec vs normal and in the R34 GTR, you would need to be VERY switched on to pick the difference, especially for street application.
Cheers
Ken
Ken,
Im not getting enough torque to front wheels during 7 grand launches, the gauge is reading max 30kg/per(whatever the measure is) rather than going up to the full 50 and I get wheel spin at rear when belting it around corners. this apparently means its an electrical issue rather than a clutch pack issue in the transfer case. Thus my enquiry about attessa pro which throws more torque up front
Cheers
Jeremy
Yeah all you guys need is an atessa controller to move more power to the front wheels. I understand the HKS ones are getting harder to find but there are a few different ones out there.
Generally if the xfer case is working OK you can adjust between 0 and 50% front torque
Ken,
Cheers
Jeremy
Jezza, I don't think I have seen any of my GTR's get to 50% and even with the HKS torque split controller, they don't get there in mine. Not saying they won't but maybe I am not brutal enough :rofl:
Virtually all the GTR's ( once again) I have had also spin the rear tyres somewhat during cornering as the reaction/action of the computer and fliud is not instantaneous. Mind you, it's is more fun than rex understeer..
Cheers
Ken
i honestly am not a genius or anything on this topic, i have limited knowledge (very) so don't flame me buuttt.....
In theory, wouldn't it be better to leave it as is and have much more rear-bias torque split rather than an even 50/50 split etc...?
I say this because i know (in theory) that the front wheels pulling on the 4wd does induce a certain amount of understeer thus I would have thought that it would be better to run a 30/70 (front/rear) split rather than say even 45/55 or 50/50 etc for the sake of being able to pull the car round a corner/curve/bend etc exceptionally whilst still maintaining a tight line... :confused:
I understand the rear wheelspin and oversteer is also an issue for consideration 'cause it can get annoying but if it was that big an issue wouldn't you turn to tyres, suspension, weight distribution etc before contemplating the possibbility of reducing the cornering cpabilities of the car by using the torque splitting.... :confused:
Then again... if it's a drag car, my theories just go totally out the back door don't they... lol!... can someone elaborate on this for the benefit of expanding my knowledge?... Cheers.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
