I think the stock ones are H11's.
I've used H4's (i think) and just wired up different cos i wanted to use the phillips 'blue vision' (the ones that ARENT blue). If you cant find the ones that just fit in normal lemme know i'll get you some pics of when i did my install.
Also - good luck taking the lamps out that was a REALLLLLY annoying, so much so my headlights are still held in by cable ties :bonk:
[edit: stock ones are not H11's, I've not used H4's. Stock ones are H3C and the ones I've used are H3]
https://www.sau.com.au/forums/topic/64534-headlight-globes/#findComment-1210247
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
