1996 Nissan Skyline GTS-T Series 2 Turbo
That "mess" looked eminently repairable anyway.
I think the fitting into the exhaust cam cover that takes the 2 breather hoses just pushes into the cam cover. Just....rotate it or pull it out?
Absolutely. While Pitworks is really good stuff, there is absolutely no reason why any other 4PK of the right length won't work. That includes belts that a few mm either side.
What I recommend: "H4 relay harness" for your Headlights, the R32 switch is passed though the headlight circuit, so it's common to see burn out switches because people have used "100W H3" or H3C bulbs, they are all shit. ALL BLUE TINTED BULBS ARE SHIT no matter what instagram ad you saw, every single HID/LED/whatever bulb is shit. Trust me, been there done that, every halogen bulb is shit. Your only real upgrade path is to retrofit proper HID projectors and ballast (or equivalent Koito LED projectors). trust me when i say i've been there done that, no replacement for displacement. And that's saying with me driving a BMW F45 with factory LED bi-LED, and my R32 having aftermaket bi-Xenon (morimoto d4s) you cannot argue with physics
Hey all , was wondering if anybody knows of an aftermarket equivalent for the AC compressor belt on an RB20det . The OEM part number is AY14040925 . Nissan themselves and every other place I have tried says this pitworks oem belt is either discontinued or back ordered. Edit: Just realized the pitworks belt lists 4PK925 in the center of the packaging , I found a Bando belt with that same number on it, can anyone confirm if they should be the same?
