Hi all.
Well as you may be aware i have been running my car down the drags the last few weeks.
Last week i got in the mid low 13's with heaps of wheel spin, this week im going to change some stuff and will run in the 12's 4 sure.
As its my 23rd Bday on thursday, come down bring your $45, helmet, long pant and long jumper and lets make it a SKYLINE drag meet.
C U There
Craig
https://www.sau.com.au/forums/topic/64545-wsid-street-meet-wed-16-2-05/
I'll be there !!
At this stage i'm 75% competing and 25% spectating.
Last week I found another 2mph (100 -> 102) and I believe their is another 2mph with some quicker gear changes.
i think i'll come too, but 100% spectating so someone can cheer on the lines with pom poms
in a few weeks i should be there 100% competing and by then i expect Eav00l to be saying 11's for sure :(
good luck benm, on more PB's, il be cheering
blitz - she has 14.5psi now, cant run 16 :rofl: need to get a head gasget to lower compression and she will push 20psi.
if i pull 11's im gonnqa run naked down the 1/4/... he he eh eh eh
make sure you post up the reaction time, 60ft and so on for this naked run if it ever happens ;)
I'm going to take my car for a run tomorrow night as well. I've been once before just after I bought the car last July and ran 14.5 when the car was basically stock. So this time with new FMIC, a little more boost (9psi) and more experience driving the car, I'm hoping to get close to a flat 14 or better if possible.
In any case, i'm getting my PFC installed and tuned next Friday, so I want to set a time tomorrow so I've got a benchmark to compare to once I run it again after the tune.
I haven't met anyone off here before, so hopefully I'll get to catch up with a few of you tomorrow (I'll be the lost looking bloke in the Silver R33 :rofl: )
The clouds are rolling in from the blue mtns altho appear to be heading sth west over c/town.
Outdoors temperature is 24.7c here at penrith (was 27c this time last week which resulted in 40c track temp)
Geeze wasn't that a massive turnout in cars. I ended up parking my car after the 3rd run to watch some of the action. Nothing like a pair of PAC Rotory Mazda's going head-2-head.
My runs:
14.009 @ 102.07mph / 2.089sec (NEW PB)
14.571 @ 96.01 mph / 2.311sec (Michelins don't like 4000rpm launch ;))
14.662 @ 95.29mph / 2.233sec (oops I missed 2nd gear whilst racing a GTiR)
So that leaves me only a bee's dick short of a 13sec pass still with a lot of explaining to do.
In detail:
R/T: 0.206 (PB: 0.035)
60: 2.089 (PB)
330: 5.888 (PB)
660: 9.080 (PB)
1000 Mph: 76.77 (PB: 79.84)
1000: 11.751 (PB)
ET: 14.009 (PB)
Mph: 102.07 (PB)
It's all down to getting more traction now :P
I was pretty happy with my run last night and I broke into the 13's which I was pretty happy about as well considering I was still having a problem getting much traction (damm Falken z386's!).
In detail,
R/T: 0.227
60': 2.247
330': 6.006
660': 9.067
1000 mph: 81.05
1000': 11.703
ET: 13.931
MPH: 101.37
It's interesting to compare times benm - your 60 foot time is heaps better than mine, your MPH is higher than mine, yet my ET was slightly better than yours...weird! I'm not sure what mods you've done to yours, but basically I've got FMIC, cat back exhaust, mines ecu (which i'm turfing for a PFC on Friday), K&N panel filter and 9psi.
I saw quite a few Skylines last night, although I didn't know who was actually from SAU. In hindsight, I should have just said hi, but I guess I'm slightly shy lol :cheers:
BTW, that 400R looked like a beast of a machine and I had both PAC Rotaries behind me in staging and they're both awesome looking cars (although I shit my pants for a second when it looked like I was going to line up against "THUMPER"...but he went after me which was good).
Good night overall...I'll definately be back in a few weeks time to see how it runs with the PFC and tune.
to say the least i was FU**KN Pissed off.
i was wondering y oi was only getting 101MPH at the end on high boost and pulling 14.0 ET
cheked my boost guage it was only on about 10psi, i got a boost leak somewhere high boost is set to 15psi and low is 12psi....
Bugger it im gonna put a head gasget on there and boost it up 2 20psi..
ill be out 4 a few weeks now guys
Tell me about it and it has been eating me up for a good 9mths now when I see other Skylines doing better ET's, slower TS's and worse 60ft's yet i'm still stuck in the 14's and they are doing like 13.5-13.9's with less power. With a 1.9sec 60ft i'd say I have an easy 105mph TS too :(
Click >HERE:)
'400R' is without a doubt the best GTR i've seen run at WSID. He wasn't even stomping it off the line, just taking off like normal and waiting for boost to kick in :)
I had 'thumper' parked behind me out the back in the lineup. I spent about an hour shitting my pants thinking I was gonna be up against him only for him to end up 2 runs behind me :) :)
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
