With the RENEW track day coming up I thought I might get a little bit of practise in @ Wakefield if anyone is interested in taking there Skyline out. Pete from SAU (fatz) will be bringing his RB26 R31 out (I think there will be some other R31s as well).
The only problem is that its a weekday (Wednesday). Im heading off to Phillip Island the next day so better not break anything!
Oh and I dont have to talk to the Government over this one... :werd:
https://www.sau.com.au/forums/topic/64565-23rd-february-wakefield/
how much,
$80 for the day on the track, $30 for a wakefield license, $20 for a stack hat ($50 deposit sometimes required, ive never paid it)
and what time
Starts at 8 am, but you can show up when you want
and what do we need.
full length clothes, closed shoes, helmet if you got one, all loose items removed from the car
Thanks SupaFly.
Spectators dont have to pay a cent unless they want to go for a ride themselves in which case they pay the full amount (I think... cant really remember).
Stevie - would be great if your mates Stato can make it out there. My mate with the green ute loves his statos (owned a couple) but wont be able to make it out, he is racing at Phillip Island that weekend, we leave on the Thursday.
Here is some advice that I found very useful by the NSCC guys...
Mechanical:
Check all fluid levels ( Oil, Coolant, Brake Fluid )
Double Check that all caps are on and secure
Check front and rear brake pads
Check all tyres and ensure that they are in good condition
Check that all hoses ( including Intercooler pipes ) are firm and not worn
Check that your seatbelts are in good condition and not worn
Personal:
Long sleeve cotton-type shirt
Closed shoes
Short sleeved shirt (its either really hot, or really cold, at Wakefield)
Helmet (if you're not renting)
Empty anything you don't need out of the car. It'll give you a good excuse to clean out the interior.
What I will be bringing is:
Spare tyre and tyre changing equipment
Locking nut
Service booklet
All the other miscellaneous stuff gets left at home. If you have a big stereo that you can remove, take it out. You won't need a street directory, so leave it at home.
While you can empty your car there, its an open-aired shed and so there's little security. Don't leave anything lying around that you can't afford to lose. I might bring a little esky with some drinks, but there is a canteen facility on-site (and if you have to refuel at lunch, you'll be heading into town anyway).
Just as importantly, make sure that you get a good night's sleep and ensure that your attitude is right when you arrive. Driving like a hoon will get you off the track, either by the marshals or by the laws of physics. While Wakefield is forgiving on people who come off the track, you still run the risk of ripping a tyre open or crunching your lower bodywork on the loose stones if you hit it at speed. And the last thing you need is to be remembered as that guy risking everyone else's rides, that eventually got told by the marshals to never come back.
WET WEATHER: The track is open rain or shine, and I'll leave it up to you whether you want to come out.
Many thanks to Brenton and Alan at the NSCC, from whom I've borrowed a lot of this content.
If it wasn't during the week I'd be there for sure.
Anyone comming to Oran Park for Fatz Track and Drift day??? 27th February (Sunday). Same deal, 8 am start. $140 for SAU members, passengers are $30, and spectators are asked for a gold coin I think...
I'm out,dammit! I wont have (a) the suspension back from the shock tuner or (B) my oil cooler and sump baffle fitted... Better believe I'm keen once things are done,though! Getting ANY time off when you work in retail is a bitch,however. : (
Yeah, mine is in the shop for a week now, radiator and oil cooler, oh and the manifold issue :)
So I even miss the fatz day :cry:
Let me know the next date though :)
    • Right, but that's in-cylinder, there's the interaction between that and the TWC which complicates things. Pulling out timing to reduce NOx is a strategy I saw in transitional emissions vehicles like stuff from 1974 or so. The two inlet runner system is interesting but I'm not sure it makes a huge difference as far as emissions goes, is it a tumble valve? I've seen stuff like that even in cars from the late 80s.
    • Hello all,   so i recently swapped out my rb20de neo with an rb25de neo( engine,transmission, wiring and the diff everything) but i just cant get the gear indication light on the dash to work when i switch to tiptronic mode. Note there is a steering wheel switch beside the shifter and i dont have that. I did notice yesterday while switching to tiptronic that the indicator on the dash started to work but it didn't afterwards. Does anyone know how this actually works? Or do i still need that steering wheel switch to be connected and on for that gear indicator to work?
    • Hence why I said earlier that I don't think the turbo Neos ever would have actually qualified as an LEV. I suspect the only actual LEVs that came out of Nissan were the NA Neos. Still call them all Neos. They all stil have the Neo-ness. Just that they don't all qualify as as LEVs.
    • It will give gains, but you wont hit 600 It will give gains but it wont get you to 600 imo. You will also sacrifice low down and you will be adding extra volume if you port match it, more so if you port the plenum runners depending and how its done I think the only time youre going to see about 100hp gains is if the car is making well over 1k kw I do have a spare set that I was going to test with, but i dont actually think there is anything worth getting going larger. I did a fair few S14/S15 and the standard TB is fairly small, I went to 60 and in some cases 64mm which is significant over the stock unit. You can also get some weird ratio changes. I think 20kw will be a stretch on a roller dyno. If I had it apart I might mill the shafts a little and not expect much, I think the stock size is still pretty good for a street/track car even with larger capacity. I might change diameter it if its a drag only car
    • Was going to say something about flog, wife, pilates, behind but I better not... No dishonour here
