Brand new garrett GT Series turbo rated at 700 hp. This turbo is also
commonly known as the GT35/40R as it has the GT35 turbine wheel
and the larger GT40 compressor wheel.
Front A/R is 0.7
Rear A/R is 0.82
4'' inlet with massive bell mouth to suck in plenty of laminar air
2.5" outlet to suit intercooler pipe work
Turbine housing: GT30 non wastegated.
Inlet: T3
Outlet :GT30
Ball bearings allow the turbo spin forever, even when spun by hand.
Item includes Garrett warranty from date of purchase.
Unlike bushed (STD wet floating bearing) turbos that need replacing/rebuilding
at 40,000 klm in performance applications, this will only require new oil seals
at 80,000 klm. This means long term savings!
Utilizing the latest compressor and turbine wheel design these have proved to
spool up even faster providing more drivability, stronger midrange power and torque
with better reliability.
Inconel turbine shaft which is extremely light allowing quicker turbo response
and heat resilient this turbo is top shelf with no expense spared.
Recommended retail is $2960
Turbo only $1950
HKS Cast manifold.
This will not crack! In addition it can be further ported, extrude honed etc for further improvement if need be. As you can see from the pic's, the design is pretty good. All runners are split as far up to the collector as possible which will give good top end and mid range performance. It even splits the wastegate gasses.
This has a T3 flange, but is big enough to be drilled for a T4 flange if required.
I usually use these with GT30/35/40 BB turbo's due to the T3 flange. Due to the low mount design, you minimize any unwanted attention from the cops! If you need more info feel free to contact us.
Manifld only $950
Manifold and Turbo combination $2700
RB25DET Apex 550 cc injectors $750 cleaned and shipped
RB20DET/RB26 HKS 680cc injectors $750 cleaned and shipped
Moderators still waiting for comeone to replt RE: Trader details etc
These manifolds are not made by HKS anymore. They now produce the Stainless ones which seem to be good! However I cant see them being tuneable in the way of further porting at a later date etc.
So basically there is only 1 available!
So that large turbo will fit in the low mount position ?
What size wastegate would i need for that turbo? HKS 60mm ?
Yes, it will fit! Nice and snug! I have fitted a couple of these to RB30/Rb25 combo's and 1 bar is reached before just 2400 RPM and 2000 with the 3040 turbo!
Wastegate size would depend on the boost you are running and if its dumping to atmosphere or plumbed back. Generally 40mm will be OK in most situations. If for some reason you want to run a measly 7-9 psi, you will need a 50-55mm gate.
Its a common misconception you need large wastegates. They are only to relieve pressure (not flow) in 99% of applications. The other 1 % is in extream circumstances. e.g Cars that have an uncanny amount of exhaust gas. I.e. RB engines wouldnt have anywhere near as much exhaust flow as a 13B even if it had an RB30 bottom end and only if it rev'd to 9,000 rpm or so.
Remember the exhaust wheel on most of these large Hp set up's flow gobs of air and only sight pressure variations are enough to control boost.
But by all means if you have the cash to flash, go big!
What's the reason for selling? How laggy would this turbo be on an RB25DET-NEO with tomei poncams...?
As laggy as a 700 Hp set up would be on an RB25 with flow to make an easy 350 rw kw...
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
    • Righto,  enough of ADHD Anonymous! 🤣🤣 Rear end is completely stripped out apart from coil overs that will take 5 minutes.  Fingers crossed it doesn't look like that for too long!   Cleaning up some bits as I go so they can go straight back on. It amazes me how good stuff looks just with a good hard scrub! That will be it for a couple of weeks. I've got ot a bit of surgery Friday that will put me out of action for a few weeks. Hopefully the motivation is still there when I'm ready to get back into it!
    • The povo spec CA18S one, yeah. All turbos had 16x6.5 5 stud and 4pot brakes.
