just asking those of you that have an imported r30 what was done to the car for rego purposes? belts, mirrors and so forth. its just i bought some retractable rear belts from a mr30 hatch and theres nowhere to bolt them, the old rear belts were just bolted to the strut tops??
https://www.sau.com.au/forums/topic/64586-compliance-on-an-imported-r30/
Rear belts you need to make up brackets that securely mount the belts above the rear parcel shelf, you've gotta brace the underside of the parcel shelf with plates so if theres an accident the bolts dont rip straight out.
Basically I didnt bother, just chucked the seats away, made up a board that covers the hole through to the boot and carpeted everything. I cannot see the point of rear seats in a DR
For a 2 door of it's size there is heaps of room in the back, my mate sat in the back comfortably the whole way to melbourne.
Mine has hatch belts in the back of it, I have just recently ripped everything possible out of the car, and cant for the life of me remeber how they were mounted, I'll have a look for ya tomorrow if I can find it all.
Didn't do the compliance on my HR30, but the mods are obvious. Front seatbelts look factory. Rear seat belts came out of an Aussie R30 (probably sedan) and mount to factory provided mounting point on top of rear parcel shelf. Passenger side mirror is Aussie flat glass. Fuel filler neck has been changed to ULP size, looks a bit bodgie, probably an adapted HR31 neck. Obviously tyres were changed to acceptable rubber.
I am guessing you're talking about a DR30, so sorry if this is irrelevant.
machg
I didn't use retractable belts, I used lap sash Clippan belts - brand new for $150 the pair and they bolted straight in. Other things done for compliance was flat mirror glass on drivers side mirror, fuel neck restrictor and side intrusion bars.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
