given his age, he may be asking a legitimate question (someone might be spinning him BS).  But dude, have a think about these things before you post - saves embarrassment.....
yeah, for sure. I wasn't having a go at boost monkey. I was making a crack at the plonker who allegedly put an RB25 into his GTR to make it RWD...
x]SPHYNX[x - kinda like putting aaaa.... let's see, 12A rotor in a falcon GT
Ha ha ha ha - you do realise that Mazda kitted out a holden HQ with a 13B rotor!!! this is JUST like your example above. it was an abomination, but they did do it... it was called the ROADPACER!!!
http://holden.itgo.com/roadpacer.html how funny!
75-78 Mazda Roadpacer 4dr sedan 13B.
Engine
Mazda 13B Rotary 654cc
4-Barrel Hitachi Carburettor
power: 135hp @ 6000rpm
torque 19kg-m @ 4000rpm
Compressiona Ratio 9.4:1
Top speed 157km/h
Weight 1575kg
HAHAH thats insane!! I think its cool :rofl: and this car was available in australia? raapp raaap raaaap coming from a HQ would be enough to make any redneck cry (mate your red motors only running on one cylinder) lol. perfect canditate for a 13bt conversion
The guy obviously does not know his arse from his elbow.
If you want your GT-R to be rear-wheel-drive then you remove the ATESSA switch/fuse/plug from the engine bay's black box (bear with me I'm not too good with car terms)
As x]SPHYNX[x said just yank out the AWD fuse
and presto you can have fun DORIFTO!!!
As for the GTS-T owner with a supposed RB26DETT AWD,
He's pulling your leg, Yes it can be done (as the GTS-4 is AWD), but the cost would be ridiculous.
The cost to set up AWD with attessa would be so enormous to be done properly that it would overall be alot cheaper to purchase a GT-R instead or a GTS-4 with an RB26DETT transplant
my 2c
Leb
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
