Hi All,
Bit of a dilemma - i'm ready to sort my baby out with a proper intercooler and cruisin round on ebay you can pick up these hybrid ones for less than $400! Having a chat with the good people at UAS they reckon they're no good at all and they want 2k to supply & fit a Plazmaman one. With a turbo upgrade i'm chasing around 200 - 250 rwkw...
To anyone thats had experience with both types of intercoolers, are these Hybrid ones really no good or are UAS just trying the big sales pitch at me...i know UAS are regarded pretty well as far as tuners go but wanted to double check before i lay out 2k for a 'cooler...
Nice one
https://www.sau.com.au/forums/topic/64646-intercoolers/
Have a look in the for sale section.
You can pick up a "Hybrid Copy" for just over $200
http://www.skylinesaustralia.com/forums/sh...ght=intercooler
I have one on my car and there is nothing wrong with them.
All that is missing is a brand name badge.
https://www.sau.com.au/forums/topic/64646-intercoolers/#findComment-1210341
sales pitch mate.
I know of a number of 200 sx's making over 230rwkw with HYBRID or copy cooler.
my mild car has about 170rwkw with a hybrid cooler.
latest fast fours has some monkey in a 300rwkw r32 RB20 with a hybrid cooler.
a couple of people on here are making over 250rwkw with hybrid coolers.
but as stated above, $400 is expensive these days.
modyourcar.com has them at about $350
mercurymotorsports.com has them for about the same price.
look around.
they work fine.
just don't get the piping kit with it.
buy the cooler and then get someone to make up some pipes for you.
the ones in the kit have had some problems with small leaks making squeeling noises.
https://www.sau.com.au/forums/topic/64646-intercoolers/#findComment-1210542
sales pitch mate.
look around.
they work fine.
EXCELLENT... :kewl:
https://www.sau.com.au/forums/topic/64646-intercoolers/#findComment-1210549
plenty of ppl on these forums are running hybrid or hybrid copy coolers ...
personally i am running a hybrid cpoy at the moment and 240kw runs just find through it ...
2k is just WAAAAAAYYYYY over the top for these sort of power figures, and the price of chinese copy coolers now ...
just my 2c
https://www.sau.com.au/forums/topic/64646-intercoolers/#findComment-1210558
the guy trying to sell you the expensive cooler is clearly doing his job.
" hey i want 2 buy a fmic for $200 whats it going 2 be like "
reply
"shit, buy the one i have 4 2k "
do you really think he's goign to turn away business and say 2 buy the cheap one and go get it fitted somewhere else?
https://www.sau.com.au/forums/topic/64646-intercoolers/#findComment-1210896
How about compared to a Greddy one though?
I mean the difference in price is not that much when you think about it ($800-1100 vs $1300)
Greddy use the tube and fin design, while hybrid uses bar and plate.
It looks like hybrid can make the power though. Resale value greddy is the way to go.
But apart from that, what are other peoples thoughts on it?
https://www.sau.com.au/forums/topic/64646-intercoolers/#findComment-1211408
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
