I reckon they look the shit ricey or not!! Wouldnt the ones with vents help to serve a purpose??(ie- heat vent for engine bay) aswell as a slight weight reduction?? Anyone got any pics of a gunmetal 33 with a CF bonnett? Im gettin one soon and I wanna see what it might look like :P
What about carbon wings?? Are they an insurance issue?? Are they also deemed ricey or do they actually serve a purpose??
Wanna save 5kg? dump the spare.. done..  cost = free..
they are mainly rice, but they can look good, esp. on skylines..
Yep i tend 2 disagree too..
Have u felt the weight of a standard R33 bonnet as opposed 2 a cf one? a bit more than 5kg lol
Also i reckon they are more racey looking than rice..just my opinion
As i have a high mounted turbo as well..vents help heaps with cooling etc.
It cracked when somone sat  on it:(
So am i right in saying that carbon boonets are manufactured just like fibreglass bonnets, i mat and resin...am i missing something or isnt the whole point of carbon fibre the weigh:strength advantages from a materials and construction aspect. Do you still get all the strenght properties if things arent vacuum formed and baked etc etc?
yes to make a carbon bonnet is the same as a fibreglass one
strength however has nothing to do with vacum forming just compisits and resin combination
hope that helps
I have a little first hand experience with what a carbon skinned fibreglass bonnet does in an impact. See, my mechanic decided to drive my car after a wheel alignment, even though he had strict instructions not to! Anyway, he didnt clip the bonnet down, and it flipped up and wrapped over the roof! Suprisingly little damage, but it "broke it's back" and splintered a little, so not worth repairing.
Luckily for me, the shop's insurance paid for a fresh one to be moulded from the original, and it was REAL fully bagged carbon! I think it weighed about 5kg all up, and was so strong it didn't need clips. The difference between this and those s##t replica ones from Sydney? is massive! I've seen plenty of those just de-laminate!
So, I don't actually think they're any more dangerous than a alloy/steel bonnet, but the mod plate guy I saw wouldn't "plate" the mod for me.
Not that the car had a cat/filters/or much legal anyway!
Well im a bit disappointed that they are just a fibreglass bonnet, but instead of using fibreglass mat, they use a carbon mat:(
For the price i just paid, the main reason i wanted it was for the vent, even though i didnt like all the shark gill bits and i think the vent is too far back to be most effecient, for the price and finish its a good deal.
Just have to get it painted silver so it doesnt look anything like some of the horrible wannabee drift cars i see on the road:(. Im an Escort Panelvan driver in disguise so dont want too much rice on my car:)
Anyone with experience with carbon fibre parts...i was of the understanding that they need to be vacuum formed with special resins and baked for curing if they are going to enjoy any real strength properties. Perhaps its time to read an article i have laying around again.
Anyway, if i come accross a alloy GTR bonnet at the right price, and i can find a good alloy welder, ill have a go at a custom vented GTR bonnet (Looks at Ronin:))
got my bonnet from customcarbon. has 0% fibreglass, its 2 layers of carbon (wet) with a thin layer of foam between, its vented over turbo & radiator, and weighs between 6-7kg ( I can hold it with 2 fingers). cost me round the $1800 mark.
got a quote from just cars.....down the bottom it said "carbon bonnet not covered"
:cheers:
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
