turbo timer vs alarm system
If you mean that you want to be able to arm the alarm while the car is still idling down, then yes you can. You just need two extra relays: one to cut the ignition feed to the alarm (so it doesn't know the car is running) and another to stop the immobilisers cutting in. For obvious reasons, these should be REALLY well hidden, just like your TT...
And for obvious reasons most people dont know how to do it properly, which makes cars with turbo timers extremely easy to steal.
Whats the point of having an immobiliser and then having an immobiliser bypass? The immobiliser mustn't be too effective if a bypass using a single relay can be installed....
You'd be surprised how many of the big brand alarms have only one output for immobilisers, and how many 'professional' installers will use only one of many outputs (and 'normally on' relays...) to simplify wiring and/or save a few bucks. In both cases, you just daisy-chain relays to immobilise several points. If you back far enough, the majority of systems will have a single point bypass.
Turbo timers are quite a useful little gadget, but as Bozz says, they are a security bypass when installed that way, so make sure it's done properly.
Making any potential risk less obvious is the trick, and many installers won't go to much trouble. Have you thought about how loud your relays are? If yours are loud, and a thief is in your car with the relays ticking away for the light flashing etc, all he has to do is follow the noise and he's in.
For this reason, the ONLY person who does electrical work on my car is a friend of mine who I trust.
    • I'm thinking that this is such a small part of the problem that you could easily forego the vac pump and just achieve 90% of what you need, which is keeping the gate open when off boost. It's not as if there are not already techniques to keep a gate fully closed under boost. After all, you have boost. Just use a wastegate actuator that will allow you to apply the boost on the appropriate side, just like every external gate out there.
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
