Ignition Timing
Guest N/A R33
This may seem like a pretty stupid question to some of you guys but here goes anyway.
How do you connect the timing light to the sparkplug on number 1 cylinder seeing that it's under the coilpack?
The way I think I would do it is take the coilpack out and plug in a normal coil and lead that way giving yourself a connecting point for the timing light.
Steve N:)
https://www.sau.com.au/forums/topic/6467-ignition-timing/
Originally posted by ylwgtr
NO!!!!!Under the module there is a wire loop that you can connect a normal clip on type timing light to.....it looks like a normal speaker type wire
hope this helps!
I have heard that loop is for factory diag i tryed putting a timing light on it and my timing was way out. i think by a few degrees as opposed to timing the actual cylinder..
Maybe someone can varify for sure because it would be good to clear this up, that loop is hell easy to attach timing light to :uh-huh:
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97209
Yep - it is the wire loop at the back of the engine near the silver ignition-module-box-thingy - says so in the Service Manual for my car anyway.
A mate tried the same on his R33 & got the same results.
A very reliable source indicated that you will get maybe a couple of degrees difference in your readings from here when compared to measuring straight from the wire going to the coil itself - but who wants to stuff around taking covers off, etc.
Hope this helps...
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97457
I have done all the work to my car but never ever done the timing on it.
So, you put the plug that was meant to go to cylinder #1 on the black loop wire on the ignition module.
Where does the other wire/s go?
dont get me wrong I am very mechanically minded but no one has ever shown me.
Doc
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97469
Hope this helps...
But a couple of degrees out is not good enough
If this loop is the output from Igniter module straight to firing 1 cylinder then it should be 100% as long as your timing light picks up low level voltages or if it is a CT Current transformer type which picks up the firing pulses as a current...
But when i tried to time it from there all i got was about 8degrees TDC with max clockwise cam sensor turn
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97595
ok....it will show up out because the car is not in service/dianostic mode........run it in service mode and you will get an accurate reading
you could be on to something there?
so use the loop and run in service mode, is there anywhere we can get instructions on how to use service mode?
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-99675
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
