r33 plastic headlights
DON'T USE CUT AND POLISH ON PLASTIC !!!!
It will **** it.... it eats away at the first layer.. now while that is fine for paint, on plastic it will screw it and never be the same ever again.
Don't do it! Maybe normal polish is ok, but no, no, no on cut and polish. Try it on some bit of plastic yourself and see what it does to it first.
Guest Boxhead
go to rice barn and pick up a bottle of that meguiars clear plastic polish stuff...
its not as big as normal polish bottle, and its light grey... that stuff works great for outside of lighst.. if your lights are fogged up, sometimes the problem is inside of the plastic, in which case you can polish teh outside all you like and it wont do a thing...
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
