heavy duty upgraded clutch will cost you around $700 fitted.
Normally $600 but the gearbox in those is harder to remove than the GTST.
Some people may do it cheaper. Make sure you replace rear main seal, spiggot bush and carrier bearing when you do the clutch also. Also make sure you ask the people doing it if those items are included in the price - they should be. If not, you are getting ripped off.
You can get a whole range of other clutches so really the prices go up from there. All I can say is do your research and specify what you want outta your ride and it's driveability. Once the clutch is replaced it will be too late if it's too hard or grabs too much or not practical on the street. You'll basically need a clutch to match your mods and HP.
Your car will be off the road for a whole day and possibly two if they are really busy or run into any unforseen problems.
