hey guys a have a set of stock S14/R33 rims for sale with legal tyres all round. Fronts have about 60% and the back 65%.
The rims are in ok condition and should suit anybody looking for an upgrade or just simply wanting some cheap drift rims with tyres.
the tyres alone would be worth about $180.
Looking for $280ono.
cheers guys
Adam
I think EVERYBODY has a set of them sitting at the back of their garage.
You could try flogging them to some knuckledragger with a falcon. They'll fit and be a decent upgrade from his 15's
