But a bit of soldering and a set of (I think you mean) resistors for about $10 and they work fine, after a tune. Jaycar or Dick Smith 10 watt 10 ohm resistors should work fine. Measure the impedence (ohms) across the injectors and then make sure the total resistance comes between 13 and 15 ohms impedence on each injector. There is nothing magic about the GTR resistor pack so don't waste a penny on one. All you do is find the power wire to the injectors and then feed that through the resistor (you need six, one for each injector) to the injector, then the wires run back to the ecu which grounds each injector to open it for fuel delivery. Very easy entry level mod.
https://www.sau.com.au/forums/topic/64801-gtr-injectors/#findComment-1212578
