ummm.. i wonder whats gonna happen if u compair with same kw on both car??
and why compair HSV with NISSAN not with a NISMO??(e.g. NISMO 400R?)
anyway nice info u've provide... but i still like Skylines more than Holden... it just looks so much better...
cheers
  • Replies 350
k_hole
Registered User
Trader Rating: (0)
k-hole you sure you aint the reincarnation of skylinekiller or a buddy of sidewndr who have all joined on Feb 2005 just to have a look at how wrong all your comparison posts are.
and non of the holden or v8 supporters have answered my question about why do v8s need a 5.7L car with that much engine power to get a car to perform the same as a 2.6L car with 1/2 the power and its 10 years older.
The most enjoyable read ever was when they compared to R34 GTR to some New HSV in a speed mag i think. Both were equally modified (just a few small bolt-ons, boost and computer), and the T34 GTR beat the Holden in every aspect from rolling start to breaking etc... There is no argument that Holden has some catching up to do!
That was in Speed magazine I think yeah
The GT-R mauled the crap out of the GTS, and the GTS even broke some of it's drivetrain (I distinctly remember the 1 week old KAAZ LSD going snap)
But I'd have to say the most enjoyable read of the kind I've ever had was in Wheels magazine in 2002 I think, R34 GT-R V-Spec 2 Nur vs HSV V2 Coupe GTS
both dead stock
The Skyline pulled the Gen3 out the Monaro's arse
and I loved every word of it.
Maybe Skylinekiller should go read that article.
Thats easy, because GM can use light utility/truck engine as the basis of a performance engine to get cheap, reliable/durable performance. Throw in some alloy casting and the thing actually doesnt hurt sitting up the front of a sports car/sedan.
The V8 saves the hassle and complexity of turbocharges adding weight and heat, extra cooling / packaging requirements, adding to service intervals of the car etc etc.
And as for fuel economy etc etc. Think about it, if you put your boot into either, they both suck gas. Power is a result of flow thru the engine, and in turn the more power you make the more air you consume and accordingly the more fuel you need to use.
If you want to compare sports car to sports car, not sports sedan, compare the performance to a Corvette, an Ultima, a Robnell Cobra a TVR Cerbera. Lotus Espirit GT or another V8 powered Coupe/Sports car.:rofl: ...You start to realise that V8 powered sports cars are an expensive breed, even 2nd hand with the exception perhaps of a 928GTS
I cant believe this thread is still going...a think some Nissan drivers have blinkers just as big as Holden drivers:(
..and credit to Nissan the R32 GTR, they out foxed everyone in the old Grp A days. Holden were homolgating an ordinary sedan, Ford a shopping trolley, BMW a mass production rwd NA 4cylinder and Nissan go and BUILD a twin turbo, 4WD car from scratch to make the most of the rules and the class. They did the best job, but they did it with a blank canvas that was the R32 series, everyone else was throwing fibregalss and turbos/throttle bodies at road cars.
If you look at the job Nissan was doing with the DR30 and the R31 in the GrpA days, it just highlights the huge leap they took with the R32:thumbsup:
Thsi debate always ends in arguments, lol, i think thats why they are started, its as bad as talkign about who's girlfriend is better looking:)
all i'm saying is that this is a gimmick and its pretty funny
people like Roy have made some good posts so its not all a loss
why does nissan need 2.6L and mazda only need 1.3L then
just curious, ur arguing a point that makes u look even worse.
if you put a 1.3l next to a 2.6l and debate it all you like,
but then if i put the 1.3l mazda next to a 5l+ engine and compare the two it would make you look worse off, so you were better of not replying to anything
besides thats like comapring apples with oranges, pointless
Guest
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
