HELP?! RB20 New head on - badly clicking followers?
Guy's just refitted head on the RB20 and found on starting that there is a loud tapping/clicking noise like the cam followers not pumping up.
DAMN was I supposed to line up the holes in the followers in the side oil rail??
Only just thought of this after hearing noise. Do I have to take the cams back out;-(
On a positive note the idle is smooth even with the 550cc RX7 Injectors and mod AFM Box to try and compensate -looks like it worked, will have to dyno asap.
Any comments appreciated and I promise to do a search soon. :)
Have you driven it yet or was that straight after startup?
Common thing with everything from RB20 to RB30
Will be noisy for ten to twenty minutes unless you prepped them first.
You will find that a nice drive around the block will quiet them up. If it doesn't then you may have other problems.
Hi 3LIT3 FORS3, thanks for that, I was starting to get really worried I would have to pull the cams again.
I had only started it about 10/15 times for a few min to get the oil going through the new cooler and to make sure the new 550 cc Injectors were operating OK.
Last time I tried them they were frozen up. This time they are all OK!
Aparently they dont like sitting around for a few months before you use them :)
Thanks again, will drive it soon.
I'm sure you will find as soon as it drives around a bit after the oil temp and pressure levels reach their operating values, the noise will disappear. It will go away if you let it sit for ages idling (like half an hour - sometimes sooner, sometimes never). With every one I have done, it has taken a drive around the block to clear them up.
Good luck with it
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
