i have a 450hp hiflow and a hks evc 4 boost controller but its not tuned and im running stock boost, once the turbo wind sound start goin after about 2 seconds there is another noise coming in kind of lick when you pinch a balloon and let the air out that reall high pitched noise but its not really that quite high pitched but a bit more dense, now ive only had my car about a month and i dont know anything about it, i dono if its just normal the turbo holding presure or what i mean it could be normal anyone help plz
https://www.sau.com.au/forums/topic/64856-turbo-sound/
A balloon pinch of air like its trying hard to get threw. Is the rubber hose that runs between your AFM and the turbo... This hose can pinch inward due to age and the amount of air being drawn. I replaced my rubber hose with a alloy part. As most do with turbo uogrades.
Cause when its made of metal it aint gonna pinch inward....
But this is strange at stock boost....?
https://www.sau.com.au/forums/topic/64856-turbo-sound/#findComment-1213537
could also be something as simple as a hose clip loose / broke etc ... the noise is air escaping from between the rubber pipe and the metal of the tubing ...
I had it befor on my mr2 tubby ... sounded exactly like this ..
do around and check all the clips on the piping ... if one looks or feels a little loose, tighten or replace it
https://www.sau.com.au/forums/topic/64856-turbo-sound/#findComment-1214139
LOL I kow that sound very well...
Very funny actually..
I swore that I had a leak in the pipework somewhere, it haunted me for months.. Then when it went up on the dyno for a few runs I got him to hold it at boost while I tried to find the leak.
It was frustrating cause with the bonnet up the noise would disapear, bonnet down it was there again...
Me and my mate where scratching our heads.. Then we found out what it was.
With the bonnet down the air getting sucked in through the bonnet crack then swirling into the stock airbox scoop was making the air whissle !!!
As soon as we lifted the bonnet about 4-5mm it would change the way the air was being sucked in and the noise stopped...
It had me frustrated for months and it was something so damn simple :)
J
https://www.sau.com.au/forums/topic/64856-turbo-sound/#findComment-1223108
J
are you serious, thats crazy, i still havent fixed it, but the other day i was putin new globes in my lights and so i had to remove the air filter and then for the arvo after i put it back on it stopped, but its back now, im goin into cypher or xspeed for a tune in a few eeks might just get them to have a look, or take my bonnet of and go up the street to see if your theary is on par
https://www.sau.com.au/forums/topic/64856-turbo-sound/#findComment-1223142
LOL - it was very funny.. We just couldn't belive it.
When it was on the dyno and doing the runs I remembered that I wanted to check it out for leaks, but we couldn't find anything. Even with a sethascope (sp?) we couldn't hear any leaks.
Then I put the bonnet down to try and keep the engine noise down a bit and then the noise came back straight away. We eventually narrowed the noise down the the front right hand side of the bonnet (where the air box is) and when I got the tuner to pop the bonnet (and it popped up 5-10 mm to the latch) the noise stopped straight away.
About then is when my mate and I turned to each other and at the same time we said "oh get f^%#ed !!!"
J
https://www.sau.com.au/forums/topic/64856-turbo-sound/#findComment-1223192
i just popped the bonnet and went for a spin, it didnt really seem to do to much it did sound a little less noisy but i think it might be my plastic pipe to the turbo, when i was lookin at it today it also had another pip on it but its been cut and pinched shut so i might just get a new steel pipe.. its got me stuffed cos it sounds like its restrictin the boost a bit but oh well such is life
https://www.sau.com.au/forums/topic/64856-turbo-sound/#findComment-1223248
i installed a 3" front and dump pipe, and i am now running about 11psi. I have noticed a similar sound. Were can i buy the alloy replacement pipe (and how much?), coz the thought of my RB25 struggling to breath brings a tear to my eye!! :)
https://www.sau.com.au/forums/topic/64856-turbo-sound/#findComment-1226497
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
