was at dyno day yesterday and the guys from DNA were out there with a couple of guys sporting their kits. quite impressive i must say.
if you haven't seen their kit, here are some pics below. most noticeable about this kit is the pipework. its reversed, inlet from the left, outlet from the right. the idea of this was to have the outlet pipe not go over the hot section of the car - in effect keeping it as cool as possible. DNA say their fmic keeps inlet temperature atleast 5 degrees cooler than conventional fmic kits...
anyone have any comments on their system? from what i can see:
-the pipework length and amount of bends is pretty much the same as any other conventional system.
-the idea of running the pipes that way is quite ingenius
-quality of parts and workmanship looks fantastic
-cost of kit ($1950) is extremely competitive.
-why havent the japs gone this way?
-will running the pipes over the hottest section of the car heat the air so much as to make the i/c inefficient enough to cope?
https://www.sau.com.au/forums/topic/6487-reversed-fmic-piping/
Guest Boxhead
ooooeeeerrrr... that looks smirfy...
umm well i could be wrong, but this is the way im thinkin... you dont really mind what temp air is before it goes through i/c.. you just want it cooler coming from it.. so.. if you have the air heatin more after it goes through, it would end up hotter then if you had hottest pt before the i/c... if the heat was worrying you, wouldnt you buy a bigger i/c? so it could cope?
its a nice idea.. and i dont think anyone will be able to just come on and say yay or nay, i think tests shoudl be done.
Well here's my 2c.
Either way there is bugger all extra heat saving. The ambient underbonnet temps will see to that. I notice this car doesn't have a cold air box either.
The nice long and very hot 'boosted' inlet pipe is going to get the underbonnet temps right up there. Heating everything from the front timing cover to the intake manifold, radiator hose and belts (No thanks).
Thermo wrapping the pipes makes the argument void. So everyone lets just do that no matter which way you put the pipe.
:cool:
Whats the dna cooler flow like? It looks well made.
Why didn't they go the extra mile and take the pipe across the front at the bottom of the radiator where it's in the airflow instead of up high where bit just adds heat to the engine bay. That's how my ARE setup is done.
:eek: OMG so many 90 degree bends! BLASPHEMY! LYNCH EM!
lol its smart, but like usually heat under a bonnet is taken as an ambient temp innit? as in hotter air will move towards where corder air is, so theoretically the air temp in all the connected areas of the engine bay will be hot... unless of course they were partitioned.
What's the Kit include? What are the dimensions of that FMIC, does the kit include cold air intake?
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
