hey guys as you probably already know the doors on a 2 door coupe are heavy, well mine have sagged a fair amount. The drivers was ok until I put on a type m side skirt. Now every time I open the door it makes heavy contact with the skirt. The skirt is mounted correctly. The passenger door is particularly bad and already hits without a side skirt.
Does anyone have any idea on how to make them sit higher?
https://www.sau.com.au/forums/topic/64896-sagging-doors-any-ideas/
ok.. well there are two methods.. first is adjusting the catch for the door itself:
Unscrew the two screws for the shackle, and there will be enough to move it up or down a little. That way you can adjust it up, down, by a few mm.. and this will lift the door, mainly when its closed. This may be enough to fix it, but generally it just adjusts the end point angle... the next is a little more tricky, adjusting the whole door.
you'll probably need two to do this.. but open the door fully..
you'll want something to support the door at the end handle (use a rag or something under whatever it is you're using to prop it up) underneath. Again, another person could be nice.
Then you'll have to undo the hinge bolts near the front guard.. basically they have a bit of adjustment in there, so you can slide the hinge up and down a few mm.. Whilst your mate holds the door closest to the hinges and pulls it up.. unscrew them, then this should pull the door up slightly. Then adjust the bolts back down. It may take a few times to get it right, and the bottom and top hinges all adjust how it works.
It's a bit of a bitch of a job, and can take a few hours of ****ing around, but in the end you should be able to fix it either completely, or a fair bit.
p.s. I've noticed a lot of sideskirts really don't have much room under their anyhow, the door isn't really designed to have a sideskirt lip wedged under it :rofl: Most seem to scrape.
Ok, Predator, know much abou the door lock mechanisms? My car door was damaged when at the mechanics, looked like it was pushed off the hoist with the door open and it dented the edge of the door.
Anyway the dent was fixed, but now the door sags woefully and withing about 30 ope/shuts the door locking mechanism is now damaged and i cant lock the door:(
So no i know i can adjust the door back up (though it might have been bent hinges:confused:) i just need to know how to fix/replace the locking mechanism:(
well the cheap race car fix is easy.
Jack up car near sagging door
Open door in question and put a car stand under it
really really slowly lower car until stand holds door. let it out a little further, say 2 inches.
then jack it back up....presto hinges bent and sagging fixed.
not sure if I'd do it to a road car but it worked fine for us twice now
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
