$220k .... yeah but these things beat the 360 ferrari any which way from 0-260km/h as thati believe is it's top speed (unmodified) where as the ferrari woudl top out at 320 if i'm not mistaken... maybe when i win the lottery
Disregards what specs you might have read, I've personally seen a 360 against a m3 csl in "control " condition, haha. Anyway, all I can say the ferrari absolutely flogs the m3 csl.
and it wasn't by a small margin either, Also the m3 comes from the factory with yoko semi slicks and put semi slicks on a ferrari it get worst for the m3.
I'm neither a fan of BMW or Ferrari, just so happen the fazza sound so horny, even more so than my daily car.
Why would you spend 220k on something that doesnt even come with a radio or aircon?
Because you buy an M3 CSL for a dedicated track car. You don't WANT radio or aircon. THAT is why you spend $220k on an M3 CSL.
If you think that price is ridiculous for a track car, you obviously aren't BMW's target market, and should stick with $20,000 skylines like I will :Oops:
The M3 CSL uses custom designed Michelin Pilot Sport Cup tyres, not Yokohamas.
Yes, the Ferrari 360 will eat an M3 CSL alive around any race track. It is also twice the price.
For reference, the 360 Challenge Stradale is something like 5-6 seconds faster around the Top Gear test track and the M3 CSL. Lap times are something like 1:22 and 1:28 respectively.
Interesting, i read that the CSL was actually quicker around a track then the GT3 Porsche, and my understandign was that GT3s made a meal of std 360s. The Challange Stradale is another animal all together.
20k Skylines...lol, ill stick with my 10k clapper R32:(
I couldn't remember the lap times for the GT3, so I looked them up...
# Ferrari F60 Enzo - 1.19.0
# Ariel Atom - 1.19.5
# Porsche Carerra GT - 1.19.8
# Mercedes McLaren SLR - 1.20.9
# Ford GT - 1.21.9
# Ferrari 360 CS - 1.22.3
# Porsche GT3 RS - 1.22.3
# Murcielago - 1.23.7
# Zonda - 1.23.8
# Koenigsegg - 1.23.9
# Noble - 1.25.0
# Gallardo - 1.25.8
# Lotus Exige - 1.26.4
# Chevrolet Corvette - 1.26.8
# Porsche 911 GT3 - 1.27.2
# TVR 350C - 1.27.5
# BMW M3 CSL - 1.28.0
# Dodge Viper SRT-10 - 1.28.5
# MG SV - 1.28.6
# Porsche 911 Carrera S - 1.28.9 (very wet)
# Mitsubishi Evo VIII - 1.28.9
# BMW Alpine Z8 - 1.29.0
# Mercedes CL65 - 1.29
# Alfa 3.7 GTA - 1.30.0
# Subaru Impreza STI - 1.30.1
# Aston Martin DB7 GT - 1.30.4
# Audi S4 - 1.30.9
# Porsche 911 turbo - 1.31.0
# Vauxhall VX 220 turbo - 1.31.3
# Honda NSX Type R - 1.31.6
# BMW M3 - 1.31.8
# Nissan 350Z - 1.31.8
# Mazda RX8 - 1.31.8
# Ford Focus RS - 1.32.2
# Lotus Esprit V8 - 1.32.5
# Audi TT V6 - 1.32.7
# MG ZT - 1.33
# Noble - 1.33.1
# Mercedes SL 55 AMG - 1.33.2
# Volkswagen Golf R32 - 1.33.2
# Volvo S60R - 1.35.0
# Ferrari 575 - 1.35.2
# Alfa 147 GTA - 1.35.6
# Lotus Elise - 1.35.6
# Aston Martin Vanquish - 1.36.2
# Renault Clio v6 - 1.36.2
# Honda Civic Type R - 1.36.5
# Saab 95 hot aero - 1.37.9
# Mazzer - 1.38.0
# Bowler Wildcat - 1.39.4
# Bentley Arnarge - 1.40.8
# Overfinch - 1.44.0
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
