I had a similar problem that went away when it warmed up.
The problem was a leak in the inlet manifold gasket. When it warmed up, and everything expanded the leak sealed up and it ran fine.
Wasnt untill the gasket blew out completely that I found the problem.
https://www.sau.com.au/forums/topic/64905-steroided-rex/#findComment-1216564
haha sterioded rexxy means it aient kool for a skyline to sound like that!!!! is missing and sounding like a rexxy
no it only just happened now
only for a few mins wen its cold but its enough to do my head in!!!
QUOTE=600hp]I'm not sure what you mean by it goes like a rexy, does this mean it sounds crap or it gets off the line fast?
thanks.
also has this always happened since you have the car.
https://www.sau.com.au/forums/topic/64905-steroided-rex/#findComment-1221765
Mine does that every now and then too.
Runs on one cylinder down.
Does sound a lot like a rex.
Mine goes away after a couple of revs, or just by itself after 10 seconds or so.
Happens very occasionally to me, and at very randow times, hot/cold whenever.
https://www.sau.com.au/forums/topic/64905-steroided-rex/#findComment-1227245
Mine was doing the same thing when cold because the ecu thought the car hadn't warmed up yet so was pulling heaps of timing out... it sucked... would come good the exact same place on the way to and from work... weird
so wat can do 2 fix this prob???
if i dothe ecu codes test will it bring up an error code???
thanks 4 da help much appreciated
https://www.sau.com.au/forums/topic/64905-steroided-rex/#findComment-1227731
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
