yes this is true today i ran 14.04 in my r32 with out major engine changes compared to my 15.09 last time at the track.
what was different
my tyres were advan 032r's ( semi comps) and I fitted drift pineapples tuned for traction. my 60' time was 2.1 and I could have run faster than 14 . boost was .95 and I"m using an r33 turbo cooler etc. I also retained the firm bilstien suspension
see my site under my car for more info
meggala
  • Replies 60
grim the melb weather was melb weather overcast and few spots of rain which kept alot of people away.
yeah the time was great I was wrapped.
as for tyres 245 45 16's on 7.5 " rims.
and the pineapples
read here to find out about them
http://www.meggala.com/driftpineapples.htm
yes its a plug :D
meggala
yes its a plug :D
meggala
ROFL!!!
watch out for Dr Drift modelling these great things. @ an industrial estate near you.
and
yes there is more. with each purchase you will get the secret hidden link to Dr_Drifts drifting exploits.
Nice work meggs, I'm impressed :D
I'm with grim ROFL at "watch out for Dr Drift modelling these great things. @ an industrial estate near you."
Very nice quote :) :) :)
If you get in touch with him, find out how the conversion went...
yes macka they helped heaps and heaps and heaps
really made a difference to the weight transfer even with the stock 205's back on it is much grippier. this is how most skylines should launch
meggala
have a look
Originally posted by macka
So u think the pineapples helped?
I have 255 grid vs and all i can manage is a 2.5 60foot time
The Pineapples are the 'only' thing that could have helped me pull a 13.8 ( I only put 1/2 the kit in --- the rear diff part ). Mine are the KCA349 whiteline kit.
I have a full HKS adjustable suspension setup but i will still need these pineapples yeah?
The damn thing is hard as a rock and get no bounce on take up just wheelspin
Maybe i should soften the dampes first as i have never adjusted the settings
You will find that even the 'soft' setting is harder than stock.
You could probably leave the damper setting tho' and just do the pineapples and run lower tyre pressure when you go to d' drags.
But, you 'NEED' the pineapples! You will like them.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
