lol cheers guys, thanks for the comments. ta also for the info about the rims, yer they do look like r34s now that it's pointed out to me.
didn't notice the guy in the driver's seat, wonder if he comes with it.
i already have an r33, bought this one as a daily driver (life's too short).
sinista: will let you know mate :)
waiting to see what it's like when it arrives, next mods will be fmic and frontbar i'd say.
Ohferchrisakesallbutoneofyouismssingthepoint (LOL) ;
Dear (soon to be) DR Sigsputnik;
the purchase of your car is something I hope will bring happiness to you and those around you...but...flame/decimate me if you will (heh bring it on) but the submission ...and I'm talkin gettin riddin of, having pored over for weeks for imperfections and months of lost weekends for the consolidation of research not to mention the lost opposite sex opportunities, through missing social invites etc to finally reach your goal has to render the procurement of a car nice but not nearly as relieving as actually submitting your final PhD thesis.
You are a legend, and let it be recorded as so. I have two Masters and 3 other post tert quals. One day I hope to have the same dedication as you and achieve the pinnacle you have.
P.S. Get layed as often as you can. You are are Doctor. Thinking of specialising?
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
