Good luck getting that translated
Its really weird. Apparently alot of the auctioneers don't write japanese, they put all their comments in english (or their idea of english) and they actually write in down on the paper with japanese letters. .. So its hard even for japanese speaking people to read..
Not to mention the scribble that is your auction sheet.. They should definately make bigger spaces for comments - considering alot of these cars are highly modified
:headspin:
well there is a few things you can tell about it without needing to read japanese. firstly, it's an accident grade car. secondly it's a 1989 model. body doesn't look too bad. some pin dents and something up with passenger side window, some sratches and possibly indicating some accident repair (not really sure). your buyer should be able to have this interpreted for you.
I can read most of it - it's definitely in japanese, LOL - the core problems with auction sheets are:
1. handwriting tends to be atrocious
2. kanji is small (often this partly to do with the size of the scan) - makes it hard to differentiate
3. they write in a 'code' - a kind of shorthand - people in 'the know' will understand it - but if you don't know the lingo/abbreviations - it can be guesswork only
If no-one transaltes it soon, I'll tell you what I can
(blacky - if you are reading this - I haven't forgotten about you, I just haven't had the time/opportunity to pass on your sheet)
Thanks for your input! =)
The details for this Auction sheet:
R33 N1 turbos
Mines modified ECU
OS twin plate clutch
Mines direct shifter
N1 headlights
Pivot tension rods
Nismo speedo
Adjustable suspension
N1 brake rotors
HKS exhaust (with front pipe)
Mines strut brace
Apexi air filter
Brake master cylinder stopper
Can the mines ecu be tuned in australia?...... And how does it compare to others like the Apexi PFC or E-manage?
:flamed:
bet he's stoked now, N1 turbos... :cheers:
Yeah i'm reading DaiOni, and thats cool, whenever u get round to it is ok. I've had a few people have a stab at it now including J exchange students and they all think its hard to read. But they all manage to get "Rigid Spacer"! .
blacky
here's part 1, I'll try to squeeze in a bit more later:
89 bnr32 GTR, gunmetal grey
* 65,710km. Km are listed as 'unclear' as the car has a nismo speedometer
* r33 rb26dett
*n1 turbos
* frontpipe (downpipe, or whatever you want to call it)
* cat-back exhaust
* mines cpu
* OS twin plate clutch
* mines 'direct shift' (??)
* rollbar
* n1 rotors
* boost meter
* lots of little scratches, including stonechip(s), and scratched rims
* there is a bit that looks like 'no factory parts' - but it's under the bit about the nismo dash (hard to tell if they are connected) - so it may be saying 'has a replacement speedo, and no original speedo' (so - can't verify kms)
I'll need to get my magnifying glass out for the rest, :)
okay, part II...
* I can't deceipher the first 'sales point' - first kanji is 'car', second appears to be 'high', I think the last is chou - which can mean condition/style. It's a total guess, but I think the inference is that this is a 'high-level car' (probably a reference to the degree of modification)
* has 17" rims
* has a 'takuu' bar (?)
* from my translation, it says "The owner has done a lot of modifications to this car, to confirm everything (on the car) come and look at it". I think, it suggests that there may be a lot more mods to the car
* pillow-ball tension rods
* oil catch can
* there's something about lock-nuts and a spare key - but not sure what (I would hope it says that they come with the car...)
* seat(s?) are worn/damaged
* the floor of the boot has been repaired
* the car has had repairs done, including dent repairs ('dent' is a very cool kanji - you learn something every day!)
* there are scratches and dents on the underbody (I'd assume there probably is surface rust too - but that is not listed)
* rear 'spo' (I'm guessing that is an abbrev. form of 'spoiler'...) has a scratch
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
