I ran mine on BP Ultimate, they said guaranteed to be 98 octane at least.... I ran it on Optimax once in a while when I'm running low n no BP seen around, but the next chance I got, I'm back on BP's juice. Only used Mobil Synergy once but didn't notice difference. But car felt difference between BP & Optimax, BP gives me more midrange power.
https://www.sau.com.au/forums/topic/6493-which-juice/#findComment-96959
Since I'm an n/a I get to use regular unleaded, but I only put in mobil, shell or caltex (shell n caltex use the same fuel anyways). Mostly mobil coz there's one across the road from me, plus I have this thing about using Mobil fuel with Pennzoil oils.
I've noticed I get much more k's out of a full tank of these 3 brands compared to any other. I don't touch independant, 7-11, or Woolworth fuel coz they found out that most of em were diluted in an independant investigation. If in desperation I only put enough of it in to get me to a Mobil or Shell station :D
https://www.sau.com.au/forums/topic/6493-which-juice/#findComment-97379
i only use optimax... shellsville from where i drive so its more convenient... ive used mobil synergy 8000 i think it is once and didnt notice anything better from it and i used ultimate on sunday for the first time as i was near Dr_Drifts and that was the only thing around and that seemed to go fine.
like everyone has pretty much said... stick to high octane from brand servos and steer clear of the pov stuff.
*remembers mate having to drain fuel tank after filling up at an ampol or amtex or whatever the *** it was as it had lots of water in it and stuffed his engine*
https://www.sau.com.au/forums/topic/6493-which-juice/#findComment-97600
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
