  • Replies 205
  Slide said:
wilch your a bitch chop mine :(
lol! hey I didn't photchop them...
My..umm...bonnet really does fade to clear like that! Oh and the moon was really orange that night, and the clouds were moving so fast they blurred against it.
Guest two.06l
  boj01 said:
Damn this is an old thread.  TWO.06L looks twice as good in the flesh.  Good job Paul and Stacey, hard work is done, now time to enjoy it.
thanks boj01, Powercruise this weekend at "the creek" then Compak Attak on the 9th April.
  wilch said:
nice ride GT33SOM.
Can I ask if that's a carbon fibre bonnet?
Where did you get it from? Every single series 2 cf bonnet I've seen has holes in it. I dislike the holes....
nah its just painted. il get the real deal someday :P
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
