that car looks beatiful mate.
Thank you
click below for the pics
http://www.niztek.com/forums/index.php?showtopic=661
what do you think?
To be totally honest I much prefer the Grey one you have :)
Not to keen on annodized rims, how bout you swap the seats etc from the Red one into the Grey one :aroused:
Thanks. Yep, lip is in the boot. Better pics soon.
Hope there'll be some of the engine bay :P
After that pic showing us the welding on the exhaust i'm sure i'm not the only one keen on seeing what setup it's running. Should be interesting to see what times it runs when you get it to the strip :wassup:
i still have the grey one until saturday.. but yeah its sold.. the red one should clean up real nicely..
i have to grap some standard seats for complience for the red one tho :P
i also have to find some other wheels.. the MASSIVE slicks that are on it now wont be any good for complience..
I have complied 4 cars in the past 2 weeks, all with similar issues - suspension, wheels, exhaust, guages, air filter, blow off valve etc.
In regards to the coilovers - its ok, as long as its the standard height. (thats what i have been told anyway).
I have a set of standard R33 wheels, airbox, exhaust so that parts taken care of.
As i said earlier, only issue i can see is the Sunroof.
Thiss thread is a little old but my question to you is why you would bother, given that it would have been much easier to just source and comply a stock car and modify it to your tastes (or exactly how this one looks) no offense but it looks like a massive job, dodgy/flaky paint, damaged sideskirts, and what looks to be an old supra intercooler grafted in a hurry to fit the car with little thought for airflow. add to that the amount of work you have to do.
It looks tough, big question is...is it that tough to warrant all that effort? Unless you've sourced it for real song....a real song.
Esp that given the prices of R33 these days.... and the idea of grafting a roof for compliance....
sounds like alot of good money going after the bad.
nxtime: As silver gtst so eloquently put it, lets see some more pics of that baby .. :)
He has a way with words, doesn't he? "Please" isn't in his vocabulary :)
I have more pics in my gallery.
My camera has a problem with outdoor/bright light pics, hence the poor quality.
hahaha its a nice gts,
paints looking nice.
and engine shots? ahhhem
Its a GTR... not to be mistaken with the more common GTS with 'R front grill and front bar.. :flamed:
As for the paint, I believe NXTIME just had it resprayed?
And yeah engine shots .. I agree with the engine shots :)
it never came with a wing, only a Nismo rear lip and the wing holes where (poorly) deleted. I want to be a bit different so I'm going with the sleek look :) Might fit a new lip spoiler and side skirts later.
It has some nice wheels coming and will definitely be dropped.
Nothing to see under the bonnet - it looks a bit like yours :)
ummm sarcasm?
and fully sick i know u got the idea, pffftttt rb26
go rb20 :)
ummm so yeah pics!
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
