Fresh from Japan pics
thanx for the positive comments guys. as im actually overseas atm, my broker is doing everything for me.( they probally washed it).
my broker owns a RAW workshop so i think he is gonna put on a stock exhaust for the compliance. thanx for that any way. if there is a problem, ill let u know. :D
really looking forward to cruising with some of u and meeting some other skyline owners. haha
Nice Blue dude.
Heres my Prince (im sorta against neo Nissan cos of the whole rivalry between Renault [owners of Nissan] and McLaren [i live n breath this F1 team], so i refer to them as Prince Skylines, Datsun Zeds etc.)
http://www.prestigemotorsport.com.au/au/st...sp?StockID=3640
Now that is Fresh Japan. So dusty u can carve it.
I was thinking about getting the bonnet cut n try n fix some sorta Grille (doesnt hafta be a GTR grille, as i kno the GTR dudes will pay me out). As u can see the dent doesnt look too good.
Also, the wheels n windows are gonna get as black as legally possible.
Hey Ron
Im actually still waiting for it. Just made the payment about 3 weeks ago.
It is more expensive than the last car i've imported (300zx @ 300,000 Yen came to $3k, the skyline @ 250,000 Yen came to $3.2k, but thats just exchange rates with 12 months different.)
I just gotta hope that the shipping price n tax etc. will be under $3k as well, to match up with Prestige Motorsports estimate. My last broker was off by about $300-400.
so we'll hafta see.
Hey Ron
so we'll hafta see.
i though ur car has already landed. its a pretty good price. hope everything goes well.
when was the exchange rate 100 yen per AUD??12 months ago mate it was 80 yen per AUD. in fact in recents weeks the rate of 90 yen per AUD is the best it's been as far back as i can remember.
  • 3 weeks later...
i bought some for around 86 per AUD when i had to pay for my car. would be pretty good if it was 100.
Yeah, I wish too. If I'd gotten my arse into gear back in December I'd have saved a few hundred.
Just blew my wad of yen at 85 to the $ on this old thing from Hokkaido. Supposed to have R33 N1 motor and R34 N1 snails.
The wait begins.
Edited by FurryBarry
If i can remember it was 90 per AUD for a few days last year towards end for the year i remembered cos i saw it on the news :P damn that would be cheaps with the rates should of bought a few cars !!
Edited by MFC05
  • 5 weeks later...
  • 3 weeks later...
89 model R32 got here via Kiwi and Toll car carriers yesterday and came through with only the boost guage nicked, which I'm happy with as they didn't touch the boost controller, turbo timer or the hand controller. They didn't nick the TE37's either and there are no new scratches or dings that I can see.
I'll post pics soon as this is what the thread is about I suppose.
Does anyone know how to get rid of the smilies menu from the post reply screen? They're giving me the shiites.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
