Fresh from Japan pics
FULL FACTORY BODY KIT & NISMO PARTS
BREMBO F40 BIG BRAKES (FRONT ONLY)
PRODRIVE 18" ALLOYS
NISMO ADJUSTABLE COILOVER SUSPENSION
APEXI CARBON STRUT BRACE
HKS INTERCOOLER
HKS OIL COOLER
HKS TWIN BLOW OFF
NISMO CLUTCH
FULL STAINLESS EXHAUST & FRONT PIPE
MODIFIED COMPUTER
Thats a great looking Skyline R32 GTR
thanks there is a small dent on the passanger side quater and scratchs under the lip on the front bar but i'll fix them when i respray it
well here is mine. it's pretty much fresh from japan. it did have a basic $20 car wash though, but that's it. came up pretty well considering. :P sadly for me it's already up for sale. but I have something new on the way. :P
well here is mine. it's pretty much fresh from japan. it did have a basic $20 car wash though, but that's it. came up pretty well considering. :banana: sadly for me it's already up for sale. but I have something new on the way. :D
Jeeez! That looks real nice! Liking the front bar..
Thanks mate. :P I like it too. Though I think it needs the nismo side skirt extensions to go with it, as from side on you can really see how much lower the front bar is than the stock side skirts. :P
here is what's next. my RX-7. it's a 2001 RZ model which means it is a bit lighter than the regular FD and it comes with carbon kevlar recaros, and BBS wheels and bilsteins plus it's only a 2 seater. I just had the engine rebuilt at pre-stage in japan which is a small but highly regarded rotary tuner. http://www.prestage.rgr.jp/workscar.html should be a fun car.
these pics are just fresh off the docks. not even a wash. :thumbsup:
damn that is a very nice clean looking rz you got.
If you dont mind me asking how much has it cst you so far??
don't really want to say. :dry: I've spent a bit on it. :) had the engine rebuilt etc all costs money. Plus now that I'm moving house I don't have as much car space as I used to so it will probably be for sale sooner or later. It's a pretty nice car though, quite low kms and I have the books for it too. It's surprising how good it looks for car that just came off the docks, it will look nice after a wash.
some info on the RZ for those that are interested. they are apparently the rarest variant of RX7 you can get. :)
The RX-7 Type RZ is a performance-enhanced limited edition version of the RX-7, Mazda's rotary engine-powered sports car. Type RZ is equipped with red custom full-bucket seats manufactured by Recaro, a custom suspension system manufactured by Bilstein, and custom aluminum wheels manufactured by BBS. These and other enhancements reduce the overall weight of the Type RZ by approximately 10kg, improving handling and performance. The Type RZ has a custom body in color snow white pearl mica color. Only 175 units of this limited edition model were sold.
Primary features of Type RZ:
- Red custom carbon/kevlar full-bucket seats manufactured by Recaro
- Custom gun metallic coloured forged aluminum wheels manufactured by BBS
- Custom dampers manufactured by Bilstein
- Custom red stitched steering wheel manufactured by Nardi (different wheel to the other models)
- Custom red stitched leather shift knob, stick shift boot, and parking brake lever boot
- Driver's side kneepads
- Passenger side aluminum footrest board
- Rear storage box
- Custom body color: snow white pearl mica.
  • 1 month later...
Straight off the boat into Tassie and met by yet another import.
And then straight down to Symmons Plains.
There in an official capacity so I only managed two laps dropping gear to flaggies etc but still on a race track at full noise on the first day.
  • 3 weeks later...
 Share
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
