Nice find. I bought one in for my brother a whiel back. Ran a 12.4 with exhaust, boost at 18psi. Pretty good for an auto I think you will agree!
I know it may make some of you Nissan boys cringe, but here is my newly purchased car.
1999 Toyota Supra TT 6spd VVT-i
It has about 98,000kms on the clock.
Mods include a full body kit, 18" wheels, coilovers, a sports exhaust and 3 x DEFI gauges.
Looking forward to winding some boost in to the ol' 2JZGTE.
P.S Thanks to J-Spec for hunting down the car for me!
  • 3 weeks later...
Damn how can u get a vspec for way under $50 k complied & regoed!?!?
This is my one bought last month. She's still in Osaka but will be on a boat soon..
1999 BNR34 Gt-R V Spec. Grade 4 / B.
I set a budget of $50k AUD or under. This car will be way under my budget when regoed so I can buy mods for it.
I'm trying to find one using the same budget too, under 50K on road for a Vspec.
Fingers crossed, had a few pop up but haven't made a bid yet after the inspection by the person in Japan.
How long did you guys wait before finding one that you liked and bid on it?
I've only been signed up for the service for almost a week now.
Kessian and mxfly, mind if I ask what you guys set as your FOB budget in Yen and how much you won at?
I hope I'm not aiming wrongly with what I set as my max FOB.
Edited by UnCo
Not sure what i set FOB, i basically said exactly what mxfly said, "i have a budget of 50k all up landed on my door". Used Northshore Prestige Motors. Paid my fee, and they found be my current car that night :( . Was very lucky in some respects.
Took me about 2-3 months to win that one. I had some cars that I liked but got rejected when they were inspected. Then a couple was approved so i bidded but lost. The blue one above that I finally won was third time lucky.
FOB price was 3 mil yen. I've seen cars sold cheaper but obviously had higher kms, lower grade, repaired, etc.
Wow, thanks guys. I guess I'll just keep being patient and hopefully can find a good example of one.
I was hoping not to spend more than 3.25mil FOB, but that's my absolute maximum if I find something worth stretching that far :D
Fingers crossed!
I was hoping not to spend more than 3.25mil FOB, but that's my absolute maximum if I find something worth stretching that far :P
Fingers crossed!
White and silver tends to be the cheapest you can buy for some reason so 3.25 mil yen is definitely achievable.
Thanks mxfly :bunny:
I landed a winning bid on one yesterday for under my budget!
Now for the gruelling wait to get it in my hands!
FULL FACTORY BODY KIT & NISMO PARTS
BREMBO F40 BIG BRAKES (FRONT ONLY)
PRODRIVE 18" ALLOYS
NISMO ADJUSTABLE COILOVER SUSPENSION
APEXI CARBON STRUT BRACE
HKS INTERCOOLER
HKS OIL COOLER
HKS TWIN BLOW OFF
NISMO CLUTCH
FULL STAINLESS EXHAUST & FRONT PIPE
MODIFIED COMPUTER
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
