  • Replies 75
a 99 rex is a lot faster in a straight line than a r33, both being stock. the rex is faster both on the road and obviously can launch harder.
if you think a rex has a shit top end, then so does a gtst they both die off at high revs(turbos too small)
just as a sort of related example, a friend had a stock 01 rex(bug eyed shape, slower than 99) and he ran 14.0 @ 100mph, slipping the clutch on the start (not a redline dump)
a stock gtst isnt anywhere near as quick.
(and i have had 2 gtst's)
I recently finished this project:
CONVERSION:
2000 Forrester (stock)- 96 WRX Engine (Front cut) 12psi = 120KW at the wheels
The older WRX's still used the same turbo but they had larger compressor housings giving them better top end.
This forrester has nothing down low but when it winds up it'll walk past a stock WRX!
This said I think the newer model WRX would have a tough time keeping up with the lighter R33 with less top end in a street situation even the older pre 96 WRX's would be struggling.
Reality is, in two so evenly matched cars the biggest decider is driver :wassup:
Maxx, the modded rexys you ran can't of been very modded at all. 180 atw is easy to get from em and being lighter than you they will pull on you pretty easy.
The 96 rexys had a different turbo too, it had more top end than the 97 onward rexys.
The current model rexes (03-04-05)are actually the fastest (and heaviest) wrx's made so far.
99's are sposed to have 160 kw at the fly too, not 180ish (i think) like the 33gtst's have.
stock 33's are around 150-160 (I think) :confused:
Hey peeps here my 2cents.. I had a go against a 98 model WRX my mods were FMIC 3in turbo back runing 11psi agint the WRX turbo back Carbon bonnet running 13psi (in controlled conditions.. both running in street tyres... first run i beat him by Half a bonnet second was pretty close too wasnt able to pull away neith was he.. maybe if i only haad 1/4 tank of petrol instead of full LOL
every lil bit helpsss haha
stop being narrow minded skyline owners.
rough numbers.
wrx = 1300kg with 160kw
r33 = 1350kg with 187kw
so power to weight is close but add 4wd and then measure them in a proper place (400m) and the skyline will lose.
no doubt.
and to make it fair, use the same year model for both. 96, 97 whatever.
rough numbers.
no doubt.
Yeah, the (goodness) ranking is something like this:
1. GTR
2. WRX
3. GTST
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
