Hey Guys,
I've been looking around for the answer to my question with no luck, so make someone can help me.
I have an rb20det with 2530 turbs, gtr pump, adj cam gears, pfc, uprated injectors, exhaust and fmic, i'm just about to have the pfc tuned, but i'm not sure if i should change the AFM to a Z32? When does the stock one reach it limits??? Should i not bother with the z32?? I would say the car would be putting out 190rwkw once tuned.
Thanks in advance
George
https://www.sau.com.au/forums/topic/65010-upgrading-afm-on-rb20det/
Its probably a worthwhile upgrade doing the pipe from the filter to turbo, it seems to have merit.
But if the pipe is sucking shut, then in theory that means there must be a measurable pressure drop accross the filter which may be worth looking at.
Think of it this way, imagine air being sucked through an open ended 3" pipe, its never going to callapse is it. Now imagine putting something over the end of the pipe, there may now be a tendency for the pipe to want to collapse due to the negative pressure.
So equate that to your air filter...if its wanting to suck close then there is a measurable restriction somewhere before your turbo:)
All true, but the inlet pipe itself is a restriction, I have seen one sucked in without any air filter at all. The convolutions, particularly around the bends are the main culprit. Since air flow is laminar (sticks to the outsides) having a smooth sided mandrel bend will reduce that restriction. As the rubber ages it gets softer where it flexes (when the motor twists on its mounts) and is more easily sucked closed. It shouldn't be high on your list of mods, but worth keeping in mind nonetheless. :D
Hey there, I have similar mods and just had my PFC tuned. My car got 172rwkw and my tuner said AFM was restricting things abit as it runs out of puff at 6250rpm.
It made sense to me with much more demand than standard and could see dip on curve, but I guess after reading here am I getting spun a load of crap or not??
thanks
i remeber martin donnon in HPI had a acticle about AFM, and he said it's only worthwhile to change the RB afm to Z32 once over 250rwkw
thanks
At 172 rwkw it's not a problem, at 80 mm diameter, it's prettty much bigger than all of the pipework. There are plenty of other cars with AFM restrictions, but not Skylines.:D
Hey Guys,
Thanks in advance
George
Hey george, i think u should be hoping for a little more than 190rwkw. Bbenny made about 220-230rwkw with the standard injectors and that turbo(hks2530) and a remapped ecu. So ulness u are only going to be running 1bar or so i think your estimate could be a little low. What does everyone else think, bbenny are you still around?
Be great to see your results and dyno graph posted george once the pfc is tuned. Oh and btw bbenny made this number with the standard AFM too :D
Us RB20 punters have to be careful when looking at dyno results. A 20rwkw difference is huge between 210 and 190rwkws, but from what i have seen can be easily accounted for by different dynos.
Inlet pipe sucking closed with no filter:( they are a horrible looking bit of pipe.
I suppose the point i was trying to make was dont go throwing a nice alloy pipe at it if you have a horrible filter restricing flow which may have been contributing to the problem. Fixing a problem is not always fixing the cause...or it may be that i like to complicate things:)
Thanks for the help guys.
i'm not interested in top end much, i want the most responsive internal stock rb20. that was the exact same request i made to jim at CRD. I'll keep ya posted how it goes.
Also i did a compression test today, i had driven the car but it then started raining really hard and had to stop for an hour or so and the car cooled down. The results i got were 130psi on 5 cylinders and 128psi on the 6th. Are these results good, bad, ungly????? or because it was cooled down these aren't accurate?
Cheers
George
hey,
i've got my pfc in now and taken the car for a light run...i'm finding the afm to reaching 4.9V on stock 32 actuator boost(2530 turbo) on a hot day. Am i gonna have trouble with this when i up the boost and have it tuned and have it out on a cold night?....i'm sure the car isnt putting down any great numbers at the moment...should i take the risk and take it to the tuner with the stock afm?
any suggestions would be appreciated.
Cheers
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
