I am getting my halogens direct from nissan and then getting them put in for compliance but leaving the Xenons intact
Why no t pull them out yourself , take the balasts and the globes out , make 2 brackets and put halogen globes in .
  • Replies 44
pretty sure they left em on.
I'll check for sure tommorrow.
The reflective casing has
xenon writen on it still.
Xenons have a bluish tinge?
Anyway I'll have a close look.
What else distinguishes them?
Of course they have the xenon writing on them , they can't remove that .
They just change the globes and cut the balasts off so you cant reconvert them .
If you look in front of the lights you can see the halogen globes .
Xenons take a few seconds to light up when you first turn them on .
Mine seemed to come on straight away, 2 red wires going into each, seemed to produce less heat than the inner lights, bulbs looked dif to inner lights with silver caps on the front of them, could see a label with WA91 on it.
But could not see if they had blu ends.
None the wiser really.
EDIT: doubt there xenons, can see engravings in the top of the light indicating they'd been changed i guess.
Yes they have silver caps on them , they dont remove them ( they are reflector lights not projector ) .
You can see the base of the globe though if you look in there .
If it looks like the one in the pic its halogen .
You will find they pull the xenon globe out and install a halogen in the fitting , once they do that you cant reconvert cause they damage the fitting .
If you take the light assembly out you will see there is no ballast there either , they cut the wires and take the balast out .
the r34 gtt has a pure white light (xenon but a lower type) like that found in most modern cars, xenons like that seen on the new Subarus (xenon with a blue hue) is only found in the GTRs right?
zymotic, i was just looking at your pics and noticed your GTT came with the GTT badges on it rear end, do you know if thats an extra only found on the sporter models?
I havent seen a subaru with xenon lights in Australia , only in Japan , wich model subaru are you talking about ?
Gtts and gtrs have the same xenon lights , you probably seen them after they have been converted to halogen and they install the blueish globes in them .
yeah right. try $1400 each that's what the quoted me. Im going to get 2 brand new headlights ($1400) and put a aftermarket xenon kit in them($4-500)prob solved
hmm really i got a left hand side for 600 from them when my friends front headlight got a crack. oh well must have been lucky
strange, I got to keep mine
I think I got to keep mine as well. When u turn them one, they sort of charge up (go from low to bright in about 2 seconds). My car was imported in 2003 (does that make a difference) and was privately imported (not through a shop etc). I cant see bulbs just a silver cone thing and yes, the light is bright white.
As for self adjusting, how do they adjust and under what conditions. I have a mate with a 350Z that supposedly has Xenons and they never move.
bummer, had a closer look and i can see that the two white gears on either side are not connected that plus engravings on the top and instant on means i got no xenons no more. I'm not that fused. If I did lots of night driving esp in darker areas i might spend the $ but rather it go towards my zorst. The halogens will do.
nah just the normal red 25GTt on the bottom right. Must admit overally I am very happy with
the car. Apart from the loose timing belt which Gavin Wood put in a new GTR one (got it before anything else went kaput) its a very good, clean car. Some of the ADR rules are dumb written by people with no common sense, considering other import cars have factory xenons. Grr esp cos they are worth $2k!
Think self cleaning means they must at least have washer jets...
my mate with an s2k with xenons has these jets.
Maybe this is because xenons prob run much hotter than halos so it
could be dangerous if debris left on the lens???
Damn ADR!! i want my xenons!!
They are much cooler than halogens and use less power but produce a lot more light a bit like fluros do .
Self clean is needed cause they say that when the lens are dirty they are not very effective .
Self ajusting is needed so you dont blind other drivers when your car points high , speed humps or crests .
I have a pair of insert plates someone can borrow.
You remove the HID globes and place these plates in and it lets you put in H1 halogen globes.
You'd need a way to wire it up though.
Its very easy to wire them up , i made a kit for them as well , wire and plates for h1 globes .
  • 2 months later...
Hi all,
my lights on my gtt have been converted Bummer! I have been looking for conversion kits like the kaixen one from bos importing. Although mine have been changed from xenon to halogen can i still use the conversion kit to change them back??? Someone on here said the kits are crap why do you say that is there something wrong with them?? does anyone know exactly what the conversion kit does????
any help would be really good thanks
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
