  • Replies 144
intresting that this sounds so much like this link i found on Nissan Silvia FS: used 044's- bosch big horsepower output pumps, two of them . 250$ea
Under the name of Milk
well surprise, surprise
that happens to be another of doridori32's aliases
see here .... http://www.skylinesaustralia.com/forums/sh...ead.php?t=65046
Not sure if you even know what a t04R is.. 1.15 a/r not your hiflow.64 crap..
stupid posting stupid crap here.
Didn't pick up the sarcasm in 33NIZ's message obviously? That was the whole point...
Replies like the one quoted above do nothing to improve your standing, particularly when you have more important things to worry about.
The contempt with which you hold the moderators and owner of this forum astounds me. You are just taking the piss out of them now.
Your name and bank account details are the same as all these other aliases that you use. You obviously think everybody is as lacking in intellectual capacity as yourself.
You have absolutely no credibility, no one belives a thing you say and no one wants you here.
you ADVERTISED the pump as a Bosch 044
you sent a Bosch 535
You falsely advertised your product and then you failed to deliver goods exacting to those advertised in the for sale ad.
Therefore you ARE liable for legal action, you ARE at fault, you are DODGY and a LIAR!
Damien: Why have you provided him with 2x positive feedback?
your truly dumber than i thought....just give damien his money back, leave the forums for good and all will be done.
it hope it works out damien mate, you definatly deserve your cash back so you can get the fuel pump you were after, dori dori man.. you can make heaps more money actually at work.. in a proper job... save this dude some greif and pick up the pump COD and get it over with.
let us know how it turns out !! :(
he is being refunded in full.. problems sorted out now
cheers
Why would it? it only ran 26psi of boost.
40psi+26 is 66.. enough to flow the car since it ran low boost.
:(:P:(:rofl:
Engine psi has nothing to do with fuel pump psi! :rofl:
Do yourself a favour and stop trying to sound technical, as we all are aware that you have no experties.
It's all about power and the pumps ability to deliver enough fuel to support that power safely.
:(    :P     :(     :rofl:
right
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
