  • Replies 144
intresting that this sounds so much like this link i found on Nissan Silvia FS: used 044's- bosch big horsepower output pumps, two of them . 250$ea
Under the name of Milk
well surprise, surprise
that happens to be another of doridori32's aliases
see here .... http://www.skylinesaustralia.com/forums/sh...ead.php?t=65046
Not sure if you even know what a t04R is.. 1.15 a/r not your hiflow.64 crap..
stupid posting stupid crap here.
Didn't pick up the sarcasm in 33NIZ's message obviously? That was the whole point...
Replies like the one quoted above do nothing to improve your standing, particularly when you have more important things to worry about.
The contempt with which you hold the moderators and owner of this forum astounds me. You are just taking the piss out of them now.
Your name and bank account details are the same as all these other aliases that you use. You obviously think everybody is as lacking in intellectual capacity as yourself.
You have absolutely no credibility, no one belives a thing you say and no one wants you here.
you ADVERTISED the pump as a Bosch 044
you sent a Bosch 535
You falsely advertised your product and then you failed to deliver goods exacting to those advertised in the for sale ad.
Therefore you ARE liable for legal action, you ARE at fault, you are DODGY and a LIAR!
Damien: Why have you provided him with 2x positive feedback?
your truly dumber than i thought....just give damien his money back, leave the forums for good and all will be done.
it hope it works out damien mate, you definatly deserve your cash back so you can get the fuel pump you were after, dori dori man.. you can make heaps more money actually at work.. in a proper job... save this dude some greif and pick up the pump COD and get it over with.
let us know how it turns out !! :(
he is being refunded in full.. problems sorted out now
cheers
Why would it? it only ran 26psi of boost.
40psi+26 is 66.. enough to flow the car since it ran low boost.
:(:P:(:rofl:
Engine psi has nothing to do with fuel pump psi! :rofl:
Do yourself a favour and stop trying to sound technical, as we all are aware that you have no experties.
It's all about power and the pumps ability to deliver enough fuel to support that power safely.
:(    :P     :(     :rofl:
right
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
