Just wondering,
When a tuner is tuning your car. They are doing it for the particular atmospheric conditions at that time.
After reading a few of the recent posts. They have said that in cold weather your car is more prone to “ping” due to the denser air. But this is also true in hot weather.
If this is the case. When is the best time to have a car tuned? What can be/is done to overcome this?
I always thought the colder the air the better.
On a cold night should a person run Less boost than on a normal day.
Thanks guys
https://www.sau.com.au/forums/topic/65064-dyno-tuning/
Got agree here, colder air is much better and prevents pinging.
Hotter air is less dense....ie
..anyway, regardless of the density, i think it's the higer temps that cause the pinging.
...but back to the dyno subject....i had mine done ages ago just for fuel/air ratios and they were spraying water onto my standard intercooler....later i though that was a bit stupid cause i don't have a spraw when on the road...sometimes i think they just wanna improve their rwkw reading to make you think they've done a good job (not all of course)
https://www.sau.com.au/forums/topic/65064-dyno-tuning/#findComment-1219476
yea i would be interested to also note what people think about tuning in regards to a SAFC. Obviously you want to get the most power out of the car by leaning the mixture out but at the same time especially in canberra our temps change dramaticly. eg summer up to 38 + days winter nights that are anywhere from -6 or so. Would you generally want to get it tuned up once every 6 months say to get the mixtures right or do you generally just leave it a little rich to be on the safe side ???
https://www.sau.com.au/forums/topic/65064-dyno-tuning/#findComment-1219533
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
