Nugget what size front and rear tyres do you have
I have 255 x 17 on all 4
Now, back on topic - Nugget, did you replace all 4 tyres? Did you replace them with the same type / size at each corner?
yeah i replaced all 4 tires i did have P-Zeros on the front and yokahama advans on the rear. now i have kumho KU21's on all 4 yeah and they are all the same size 17x255 40's
it just feels so much different like really lacking power. like i can be doing 160 in 5th and put the foot down and the torque will go to 10, but its also depends how much i put the foot down, half way it will only go in the middle of 0 and 10. before the new tires and wheel alignment it would only really go to the front if i launched of quick snap second quick or take a corner kicking it out. but once moving it would always drop to 0 at the fronts.. which was good. but now as long as i have the foot down it will always sit at 10...... see that could be normal but it felt so much better the old way.
my coments on the abs is it doesnt bother me so much cause i have mostly driven old shitters with no abs so im used to it, but i have to say abs has saved my arse a few times when skipy's and cars that have pulled out in front.
If you can't stop properly without ABS, you are a retard and should not be driving on the road.
And would you say the same about brake boosters grandpa.
Get with the times old man.
Or are these new fangled inventions just too much for ya.
ahahahaaha
ABS is a good thing, it helps assist people that dont know better in an emergency braking situation... not everyone is Ayrton Senna.
I have ABS disconnected in my cars, i hate the pedal feed back when it comes on, and more importantly, relying on ABS is not a good thing at all, there are instances when ABS will not help you in the slightest and no matter what, you are a passenger in your car.
I agree that when you are going to learn to drive a car hard/fast, you need to be able to drive relying on as little as possible to be a truely great driver.
But some people are retards and need ABS and aircon.
hehe j/k
ahahahaaha
hehe j/k
This is exactly true.
All I am saying is....don't go and cut someone's brake lines and not tell them about it.
And before anyone reply's to that, I don't mean that literally.
I'm sure Nugget_GTR can manage to brake on his own without the ABS.
And I'm sure that always_me doesn't intend to put Nugget in danger.
But....you have to remember that Nugget is relying on the words of others who may or may not be more experienced than he is. If you are to offer advice here then make sure you know the consequences so that Nugget can make up his own mind.
Hahaha, what?? when did this turn into me not being able to brake.
I was asking why my torque would be different now that i got new tires and an alignment.... i think someone said they where tied into the abs system.... for the record the GTR is the first car with abs i have had, used to rally the old 1980 323 RWD hatches.. they where the best. ABS does have its advantages though.
anyway how about the torque issue??? hehe :cheers:
Hi Scott,
Do you have the same brand and size tyres front and back?
Did you get all 4 tyres new at the same time?
Any variations in size can cause the torque to go to the front.
Yeah got all 4 at the same time all the same size all the same tyre...
i might get someone to check out the susspension cause i think there is a camber issue for the front wheels.,,, could that cause it??
LOL!
Don't want 4WD?
Don't want ABS?
And you've got a GTR? WTF were you thinking? You should have bought an AE82 Corolla!
I never said i didnt want ABS i was just carrying on the discussion
And i do want 4WD just liked it the way it used to be thats all was more aggressive you could say.
what was i thinking when i bought the GTR... "I want godzilla" plus i wanted something that wasnt so common.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
