Power FC surging/hunting idle after warm up
maximajim
 Share
Hello,
I recently installed another Q45 TB and TPS. The PFC will now hunt for idle after warm up. Goes 800-1500 rpm surges. The standard ecu does not do this nor does it have a code. However the standard ecu does idle higher than before. What is the hunt an indication of? TPS volatge is ~0.60V at idle. Base timing was checked at 20.
Thank you.
I remember a while back when sorting some idle problems on my RB25/30 DET R33 with PFC, that at a certain very minute openning of the throttle, just passed closed, I could induce this same hunting condition repeatably. I also came to the conclusion that the idle control algorithm of the PFC was inferior to the standard ECU, but I managed to fix it eventually after much hair pulling.
What engine are you running ....RB25,26...I cant really see clearly from your avatar? The 26 has a throttle switch as well as a TPS, wheras the 25 only has the TPS. I assume you have the correct PFC for your engine? What AFM are you using? Have you removed the screens etc?
  • Like 1
It's an rb25 with rb25 pfc. AFM is standard and untouched. I have a feeling the pfc just doesn't like the new tps. I have reset the pfc to no avail.
funny thing when setting the TPS i had a voltage of 1v at the sensor using a meter but the fc datalogit screen would show .65v. I have corrected the snsor voltage but no change.
the problem you are having sounds like a badly adjusted throtle position sensor, who did the install
also check your idle speed on your power fc if it is to high you will hit the idle limiter and it will also do the exact same thing you are explaining
  • 8 years later...
How did you fix it, I installed a bigger turbo and type b tomei cams and I have a constant hunt at 900-850rpm under, so I have the idle higher to stop it but if not hunting runs rough on idle. Tuner could not tune it out, replace afm and made it better but not fixed. Adjusted tps to correct position and base timing is 15deg
Edited by Jayden.K
Fix TPS, you may need to do a data init and do the idle re-learn, which shouldnt be a problem if you have datalogit.
As suggested above play with the idle settings, this is easier to do in FC-Edit as you can adjust them more then just on the unit itself
If you have a wideband (or even without one) try to richen the tune up around the idle cells. Easier with a wideband cause you can aim for around 14:1 AFR (they seem to idle a bit nicer around here) and play with the timing. Mine runs better at 20 degrees all around idle
Ok sounds like I need to hit my tuner up again for that idle learn. As he believed it was something else. I tried mucking around with the idle screw with the solenoid unplugged but made no difference. Cleaned my earths up and made no difference. Removed my idle screw and was fairly clean. I tune with a wide and bit run a narrow band. I have been thinking my fc is cactus. But I'll ask my tuner he is not one to skip corners
you dont need datalogit to do DATA INIT
but you will loose the tune, so if you don't have a copy or have it saved then yes get datalogit and back up the tune first
there is a procedure to follow when you do DATA INIT
and if you dont do it properly the idle is ass and sometimes results in instant-stall skyline
so read the pfc faq on DATA INIT at paulr33.com
if the TPS is wrong or off scale and isnt in the idle range then the if may tell the PFC the throttle is actually partially open, when it isnt
so as the others have said, dig up the nissan spec manual, find out the voltage range the TPS should be for idle and set yours to match that
the PFC will copy what the standard specs are so ensure it is aligned to that
ie if the spec manual says idle or closed should be 0.035 v then make sure yours is the same
Wiring?
 Share
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
    • So I checked this out in the weekend.. and look at this. I remember watching the videos. Finally got to see it in person! BRB. Tissues. Got tonnes of other pics and videos too.      IMG_0171.mov IMG_0113.mov
    • For anyone who might be put off by the slightly wacky wheel offset shown on the box photo above, the production models are not like that. Here's some more pics of the actual product (as well as the interior)
