  • 4 weeks later...
I'm not sure if it's true or not, but I heard that an S13 silvia stock exhaust is the same as an R32 ... at least catback
If this is the case we have a stock S13 exhaust you could probably borrow/have
familka: you are right...but when i raised the tein ha's the springs became to stiff/tight and the exhaust needs a bit more work than just a cat. So to pass pits i was gonna use stock bits :)
Update- stock suspension and cat have been sorted.
I have rear belts.. for R32 - the factory nissan items from japan (not ADR belts however). If they are ok, then let me know, and I can post.
I think in WA you can get by with leaving in the Japanese belts, but you will need to check.
