GTS-T R33 Series I or II ??
AlphA
 Share
65 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ok, well Ive put a small deposit down on this car pending a full check over next friday at Hyperdrive so im not 100% locked into getting this car however the price is VERY good its done 88'000kms, its manual and Its advertised as:
GTST - MANUAL Series II M-Spec 1996
Now the front bumper/body kit was very badly damaged when he drove it up/down somebodys drive way "explains why its got a new one unpainted on the front"
But its not a SII front at all is it??
Im attaching some picktures so you guys can ahave a look and let me know what you all think.
Series 1. 1.5 or 2
* its advertised as II and I looked on his rego papers and it was registered as a Series 2.
  • Replies 57
I dont think it had a passengers side air bag. The dash and everything looks so damn clean.. almost looks new.. Its on a slight tilt towards the driver " the radio etc etc.. isnt that a series 2 design?
Butler: Yeah? The front bumper isnt stock
if it didnt have a passanger airbag its definatlly not series 2. But because it does have one in steering wheel it will be series 1.5 hey. Have a look at some pics for a 95 skyline and a 96 you'll see that the steering wheels are different. Those pics show a 95 (series 1.5) steering wheel.
Ahh man.. Im worried now.. It must have at least one airbag because it says SRS airbag under the bonet, It also is dated as a 1996 build under the bonet.
Cheers pozza, Im going to look into the 1995 and 1996 models a bit more..
Its 100% a 1.5...
Has a series 2 motor with series 1 interia and series 1 front end (ie grill, bumer and most importantlly headlights... The series 2 has different head lights. If its a 96 model it cant be a swries 1.. It can only be 1.5 or series 2....
Must be a 1.5, as why would someone replace series 2 stuff with series 1 parts...
Sounds dodge, I've seen a Series I for sale from the dodgiest guy I've seen and it was badged under the bonnet as a 1997.
He even asked me what's the difference between a I, II model !
I think someone on here has a way of telling the year by the chassis number of something,
No that's not a Series II at all, headlights, bonnet, grille, front bumper, interior are all indicating Series 1.5. The only part which is the same as a Series 2, is the colour coded [skyline] panel at the rear, but all you have to do is paint a Series 1/1.5 clear part and it looks the same as a S2.
Guest
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
