scary experience tonight - beware of leaves on ground
had a very very scary experience tonight
was driving down kirham (off beecroft road) at around 9pm
those of you from the hills should know of the area before the bridge above the m2, it comprises of a few twisties but nothing too dramatic
i was literally going 30-40 km/h as it was raining and i couldnt see anything
anyways, on the last turn, my back wheel stepped out and spun out (lost count how many circles i did but time sure did stand still)
luckily, there was no cars coming the other way as i basically spun and stopped across both lanes and i doubt they wouldve seen me
also, lucky i didnt incur an damages to the car nor was there anyone around
a later inspection showed a large number of leaves and sticks on the ground which probably resulted in loss of traction, i have decent tyres with decent tread
i wasnt being stupid and was driving very slowly, so i suppose it couldve happened to anyone
anyways, just a warning to those travelling in leafy areas and in the wet
same thing happend to me getting off the m2 heading down to chatswood on dehli rd down the hill, was driving and bmw when i was franging it a little and geard down and copped some nice compression lock up and goooooooooooooooooooooooone couldnt stop the back end going faster then my front end, lucky was late at night no cars or would have been big pile up. never again. i shit myself badly ( only thing was wet or leafy, just wanted to tell the story)
glad to hear you guys were both OK.
They were pretty ugly conditions last night, but it sounds like you probably should have been going slower still :D Leaves, Oil, mud any of these things can catch you out
BTW Takumi would have headed for the leaves directly, slid past you, and won the race
yeah, shouldnt you guys already know this from watching initial d? :D
nah I've had a similar thing happen to me mate - i was going around a long sweeping left hander when it was wet, i was doing 30km/hr (in a diesel merc) and not braking/accelerating - and the back end stepped out. luckily i was able to opposite lock and feed in some accelerator to shift the weight back a bit, but i still didnt regain traction, feed in some steering the opposite way (fishtailing kind of) whilst trying to get traction back through the accelerator...
finally gripped to the road, 5m before the front of a truck in the other lane!!! the guy in the truck was dumbfounded, from his point of view, this old merc (with P plates :)) just came sliding around a corner and almost whacked into him...
he was beeping his horn and giving me nasty gestures - but of course i didnt do it intentionally...
but yeah, same thing dude - low speed, not doing anything stupid at all - and it just slid out (no leaves on this road tho, probably just oil) so be careful out there guys! glad to hear you're alright tho... lucky, very lucky!
ahh the other thing I should mention....tread depth makes a hge difference to grip in the wet, much more so than in the dry.
skylines tend to have a wear problem on the inside rear tyres if they are lowered at all so you might find that they look OK on the outside but a re crap on the inside
Takumi probably would have dropped a front wheel into the gutter if he needed to to get around you as well... :cheers:
Seriously though, don't forget that wider tyres generally have LESS grip in the rain than narrow tyres because the wider contact patch can contribute to aquaplaning - the wide tyres will drive OVER the water, whereas the narrower tyres tend to "cut" through the water and grip the road surface underneath.
Anyway, regardless of whether you've got a phat set of wheels with wide tyres, or the stockers with 215's or whatever, ALWAYS buy the best tyres you can afford. Remember that the tyres on your car are the ONLY real contact your car has with the road.
Good to hear that both of you are safe anyway.
Nick T.
i used to go thru there to work (going toward epping. now i go through north rocks rd)..
but ye i feel a the rear lose it a little even in dry whether coz the road is quite bumpy and has lots of small pothole type holes there which help in traction loss.
that's lucky no cars were coming from the opposite direction or ur poor skyline would of been hammered :|
word, even over mild standing water at 80kph, the car wriggles and jitters like the HICAS is going off its nuts. The rears were aquaplaning, not fully, but enough to ensettle the rear end.
On the F3 going home one night in the wet at 120kph, driving over a wash of water (water coming from one side of the road to another due to the camber of the road and gravity) the back will lift up entirely and sit itself down again pointing a few degrees away from the direction of travel making you shoot off into the other lane before bring it back under control. Scary stuff and I always slow right down to 80kph right awy untill I get my kajhones back D:
Fresh tyres on the back makes the car feel so much better, like it was dry.
I think its most likely because one wheel will aquaplane first, making the toe-in on the other wheel push it, then the other wheel will plane, and the same goes for the other wheel, making you shake around.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
